First post, by kneedragger37
I have a Pentium 100 machine running DOS 6.22 and Win 3.1 that I strictly use for gaming -- I want to add Win95 with a dual-boot configuration. Here's the thing -- I've been told to get OSR2.5 (Win95 "C"), as it clears up most of Win95's bugs and supports FAT32. Obviously, DOS 6.22 is running on a FAT16 partition. The machine has two HDD's (1.6 GB each) and I guess I could set up one with a FAT16 partition and the other with FAT32, but my question is, is it worth the trouble?
The only reason I am installing Win95 is to play some games that will not run on DOS. Do I gain some significant advantage with FAT32 over just keeping everything on FAT16?
Reply 2 of 15, by DosFreak
Also larger partition sizes.
DOS/9x FAT16=2gb partitions sizes.
NT4/2000 can use 4gb FAT16 partitions size.
Make your games work offline
Reply 3 of 15, by MiniMax
Rank Moderator
Moderator
I don't think it makes a big difference which way you go. If you desperately want to keep your DOS 6.22/Win3.1 install, put Win95 on separate FAT32 partition. But if Win3.1 is not important to you, and since Win95 comes with real DOS anyway, you might want to scratch your current installs, and use DOS/Win95 on FAT32 everywhere.
_________________
Reply 5 of 15, by Kreshna Aryaguna Nurzaman
But beware that you need to boot with DOS 7 to access FAT32 partitions --you should prepare your DOS 7's CONFIG.SYS and AUTOEXEC.BAT accordingly to play DOS games.
Kreshna Aryaguna Nurzaman.
Reply 6 of 15, by abyss
Dos 7.0 does not have 100% backwards dos comapitability
6.22 has better backwards compatiability and it won't make much of a difference switching the fat's. Windows 95b is just as good. Never seen 95b crash. Just stick to 95b. 95b is just as good.
Reply 8 of 15, by abyss
Use windows 95b a lot. It does not crash which it is awesome. You can't crash windows 95b. If you see a crash make a youtube video for proof because i have not seen it crash. Windows 95b cannot crash.
Reply 10 of 15, by kneedragger37
Doesn't really matter to me... my drives are only 1.6gb a piece, so FAT16 is fine. I was just wondering if FAT32 was significantly faster (which according to most responses here it is not) and if there would be some problem or instability if I ran Win95 "C" (or "B" for that matter -- I read that "B" supports FAT32 as well).
I don't want to be bothered, and like abyss said, DOS 6.22 has better backwards-compatibility for the old DOS games. I really only want two boot options: DOS 6.22 for the DOS games and some version of Win95 for the 95 games. I'm just into the nostalgia of playing the old games... I don't have nostalgia for creating endless boot files so there's an option for every game I play... those days are long gone...
Reply 11 of 15, by Kreshna Aryaguna Nurzaman
Several months ago I was asking the same question.
eL_PuSHeR wrote:
Windows 9.x would crash even without doing nothing.
🤣 touche.
Reply 13 of 15, by Jorpho
There are DOS drivers that allow FAT32 access. I seem to recall that the DRFAT32 driver from DR-DOS works well enough with MS-DOS 6.22.
And I for one am still not convinced that there's much of a reason to chose Win95b over Win98 (or at least Win98 with 98lite installed).
Reply 14 of 15, by swaaye
I dunno. I've played an awful lot of DOS games in DOS 7. Maybe there are some that don't work, but I'm not sure I've ever run into one myself. It's more likely that the new hardware you are undoubtedly running with Win9x and DOS7 (vs. DOS 6.x era stuff) is the culprit of instability.
And yeah, saying Win9x is some sort of paragon of OS stability is not exactly very realistic. 🤣. 98SE is the best of that bunch, but still, heh.
Reply 15 of 15, by jthieme
I keep a Fat16 partition on my Win98se machine just for absolute compatibilty but I don't remember finding and games that don't work with Fat32 but work with Fat16, of course with disk utilities the story is different. The biggest issue I've seen with games on Fat32 is that a lot of them don't like to have space or free space greater than 2GB which Fat32 enables. But seeing as you already have Fat16 and don't need the large drive support I don't see any compelling reason for you to covert to Fat32. If you keep them Fat16 you will be able to see all files on both drives in either Dos 6 or Win95.
Also you may want to consider going to Win98SE instead of 95 as it is even more stable in my opinion. And aside from maybe a slightly smaller memory footprint I don't know of any advantages Win95 would have over Win98.
