Reply 80 of 80, by dr.zeissler
Lot's of informations here... I currently use ATI 4.10.2440 on my onboard RageIIc. I am using Win95b with DX5 drivers installed.
I do not want to upgrade to a higher DX-Version because games that require DX6 do not run on that low end machine either.
The RageIIc does not support opengl, so there is no way of getting gl-doom/gl-quake to run in it. I use winquake/doom95 instead.
Are there better drivers for my setup? what would be you recommendations? Does the RagePro Tweaker 1.0 support the RageIIc?
Thx
Doc
Retro-Gamer 😀PowerMac 6100-66/Houdini 486/66 - G4 Cube 450/Rage128pro OS9.0.1 - Macintosh LC/Apple IIe Card OS6.0.8 - Acorn A4000 Archimedes - Unisys CWD 486/66 + Aztech Washington
