First post, by retro games 100
Installed this card in to a P3-based mobo. When it plays sound effects, the effects sound *much* faster than they ought to be. Like 10 times faster than they should sound.
Reply 3 of 9, by retro games 100
Hello.
I tried the following -
device = c:\proaudio\mvsound.sys d:1 q:5 s:0 m:0 j:0 t:1
But the sound effects are still *much* too fast. Please note that during the PAS16 setup, I selected not to have SB emulation, and also not to use the joystick port or also not to have MPU-401 emulation.
When I play a dos game, the music sounds like a typical soundblaster - it sounds like typical FM chip based music. I am completely new to the PAS16 - is this the only way it can play music, or is it possible to have the PAS16 music sound better than your typical soundblaster? (Is it as good as a GUS for example?)
When I run the PROAS.exe program, I see the following information -
Spectrum Information
IO Port: 0388
IRQ #: 05
DMA #: 01
Thunder Board Information:
Active: 00
Port: 0200
IRQ #: 00
DMA #: 00
The board has a 16-bit DAC
We have the MV101 chip.
MV 508 mixer.
The FM chip is a OPL3
There is an enhanced SCSI interface.
Thanks very much for any additional assistance.
Best regards, Robert.
Reply 5 of 9, by Amigaz
Thrillo wrote:
On a related note, is the PAS16 a SBPRO-compatible card, or is it only SB 2.0-compatible?
I've seen conflicting information about that on these forums and the rest of the internet.
It's SBPro compatible....
My retro computer stuff: https://lychee.jjserver.net/#16136303902327
Reply 6 of 9, by Cloudschatze
That's because people keep spreading misinformation...
The PAS16, and all MVD101 derivatives are NOT SBPRO compatible. Mediavision's later, non-PAS cards are, however.
Robert,
Try a DMA setting of 3 or 5, along with IRQ 7.
Reply 7 of 9, by retro games 100
Thanks for the DMA setting of 3 or 5, along with IRQ 7 suggestion. Please let me try this asap - but *right ATM* I have removed the PAS16 card to test out another sound card (awe32 ct3990) which I am also having problems with!!
Reply 8 of 9, by Thrillo
Looks like I won't be getting a PAS16 then. I was hoping that it was a solid SBPro clone with additional features, but I guess I'll have to keep on looking around for the perfect DOS sound card...
Reply 9 of 9, by retro games 100
Message to Cloudschatze:
Re: "Try a DMA setting of 3 or 5, along with IRQ 7."
Using the PAS16 install.exe utility, I tried these values, and also a lot of other combination values as well. Unfortunately, whenever I use the PAS program called "play.exe" located inside the c:\proaudio folder to play the test file called "test.wav", it always sounds much too fast.
I also tried running this PAS program - "playfile.exe", but it displays the following error message -
A Pro AudioSpectrum /CDPC card is not installed!
Please note that if the PAS16 sound card is just a "sound effects" card, rather than a musical card (like a GUS for instance), then I am not interested in spending too much time in trying to get this to work.
Thank you, best regards, Robert.
