First post, by dummzeuch
Hi,
I am trying to access a device that is connected to a usb-serial converter which makes the device available as COM5 in Windows.
I have changed the configuration like this:
serial1=directserial realport:COM5
When I start DOSBox, I get the message:
Serial1: Opening COM5
But as soon as the DOS program tries to access COM1, I get:
Serial1: Warning: Tried to activate FIFO.
Serial1: Errors occured: Framing 0, Parity 0, Overrun 1 (IF0:0), Break 0
And then the program hangs.
The same happens, if I use the real hardware COM1:
serial1=directserial realport:COM1
Result:
Serial1: Errors occured: Framing 0, Parity 0, Overrun 8 (IF0:0), Break 0
(The number of Overruns changes from one try to the next.)
It works on native COM1 on Windows XP without DOSBox.
I would prefer using an usb-serial port converter rather than a native serial port, but would settle for native it usb-serial does not work.
Any hints?
twm
Reply 2 of 2, by dummzeuch
Try the build on my homepage (button below), it has FIFO support.
Which button?
(Ok found the download, just clicked on your profile. But there was no button that I could see.)
