First post, by un3nabled
Hello, I'm new here. Can you please help me? And by the way, nice to meet you all, please look after me.
I do enjoy playing old DOS games (for the nostalgia mainly) but as you know it doesn't matter how old they are, if people enjoyed it back in the day. So recently I dug up my parents old Compaq Prolinea 4/33s from the basement. It had not been powered up for the past 9 months (being busy with HSC...)
Here are the details of the Prolinea system for reference:
System board 160420-001 (ability to take 486SX and upgrade processors like 487/ODP besides 486DX)
-80486/DX2 66 ODPR (Overdrive with standard 486 pinout).
-32 MB of 70ns RAM (made up of 3x 8 MB 72pin, 1x 4 MB 72pin and 4 MB onboard)
-Tseng Labs ET4000/W32 local bus integrated video adapter with "MUSIC MU9C9760V" RAMDAC (reading from chip label)
ISA cards:
-Digital DE305 NIC (did not test recently... yet.)
-Creative Sound Blaster CT1350B (works well, both ADLIB and SB.)
-Adaptec AHA-1520B SCSI-2 host adapter (added boot rom, used for the 1 GB hard disk, and external CD-ROM and ZIP.)
Anyway, I first had the machine working with the Sony Bravia EX500. All was good, the machine powered up and was happily running DOS 6.22. I was able to play VGA games, such as Jazz Jackrabbit, Skyroads and Lemmings, and Wfw 3.11 ran fine (using ET4000/w32 driver.)
Now, I brought the machine over to a friends to play. He had an old "IBM 9515 Color Display" crt, which has the DB-15 connector. Little did we know this was a fixed-frequency XGA-2 monitor (quick google confirms), so what resulted was a rolling picture, distorted mainly horizontally. There was a terrible whistling coming from the monitor's flyback. I quickly unplugged the monitor by the VGA cable from the port whilst both were still powered up and replugged it to make sure it wasn't a bad connection (big mistake), but same result. So we quickly turned both off. We took the computer back to my place and connected it to the Sony Bravia. Everything worked as normal (VGA and all), or so I thought.
Now, yesterday I connected the Compaq to my HP vs17 LCD monitor. All looked good at boot, the text is legible as you should expect, displaying BIOS ROM version and memory. Everything at DOS prompt looks fine (no distortion). However, when I start a program that uses VGA mode, the program tells me that no VGA is installed! This applied to games like Jazz Jackrabbit and Jetpack, of the ones I had time to test. Skyroads ran in a sort of CGA or EGA-like colour mode (looked terrible.)
Now here's the funny part. I started Lemmings. When I ran AUTODET.EXE, it pointed to "TANDY 16 colour". What? Usually it points to VGA. Despite this, I was still able to start VGALEMMI.EXE in VGA mode, and the colours were all normal as you'd expect from VGA DOS Lemmings, no glitches whatsoever.
Also, Wfw 3.11 worked fine too, proper colours and no problem loading driver.
Not knowing what the problem is, I stripped the machine down, whilst still attached to the HP vs17. I removed all ISA cards, and all 72 pin SIMMs, leaving only the 2 floppy drives for booting. I even reset the BIOS CMOS by removing "clear password" jumper for >10 seconds. I made a fresh DOS boot disk without even a memory manager or TSR. But no dice. Every time I boot the machine to DOS from floppy, Jetpack refused to run.
Now, previously before this year, I had run this computer with this HP vs17. And it did work fine as I was able to play Inner Worlds and others on this very monitor in VGA.
Now, I only have a normal understanding of old computers, but I do know that quite a lot of connectors such as VGA are not meant to be hot pluggable. I am scared that I damaged the embedded graphics card by hot-plugging the IBM monitor that is not supposed to even work with this computer. I am not an electrical engineer (yet) but it could be possible that there was a DC potential difference between the monitor and the computer, but both were plugged into the same powerboard at the time. Still I only have a hobby level understanding... (more like Year 12 Physics level...)
Well, I only have the HP and the Sony displays to use at the moment (I do have access to a few older CRTs at my grans' basement.) I connected the computer back to the Sony Bravia and oddly enough, the VGA was working again! Even with the same boot disk, I had Jetpack running in VGA (instead of the error.)
I have noticed that monitors may have something called DDC that notifies the video adapter of their capabilities. But on such an old machine? I decided to experiment, to risk, by booting the machine without the Sony Bravia VGA connected and then plugging it in well after the BIOS was loaded. Text was normal, with expected BIOS output. However, when I try Jetpack this time, it reports the error! No VGA! But by power cycling the computer (Ctrl-Alt-Del didn't restore VGA) the computer had "regained" VGA capabilities again.
Also, the funny thing is the Tseng VESA TSR still installs if I try even when other programs can't find the VGA. Don't know if this is related. No difference with TSR or not.
What do you think this is? Is it possible I stuffed the video? I will continue to search on this in my available time. I do want to use the HP vs17 in my room because the rest of my family does use the Sony Bravia for watching TV and stuff.
Thank you very much for taking your time to read this whole post! Sorry for dragging on.
