VMWARE v3.1.1 Build 1790 versus VPC v5.0 Build 350 Benchmarks
Emulation of old PCs, PC hardware, or PC peripherals.
Postby DosFreak » 2002-9-01 @ 20:27
VMWARE v3.1.1 Build 1790/VPC v5.0 Build 350
Both PC's using 16GB Expanding images.
Both tested under Windows XP Professional
Both tested with 256mb RAM
No additions on either OS but Video drivers from Vmware additions installed on Vmware
Host is Windows 2000 Advanced Server SP3
Both guest images located on same host partition.
Both guest OS's installed cleanly.
CD benchmarks were taken by using Daemon Tools on the host to emulate a WinXP Pro Corp CD.
CD was captured under the guest
Sisoft Sandra 2000 Professional SP1 v2002.6.8.97
CPU Arithmetic Benchmark
[hr]
Dhrystone ALU: 4491MIPS/4053MIPS
Whetstone FPU: 2261MFLOPS/2039MFLOPS
Test Status
Parallel Test Execution: No
SMP Test: No
Total Test Threads: 1
SMT Test: No
Dynamic MP/MT Load Balance: No
Processor Affinity: No
Standard No Runs: 64000 / 640
Processor(s)
Model: AMD Athlon(tm) XP 2000+
Speed: 1.64GHz/1.61GHz
Model Number: 2000 (estimated)
Performance Rating: PR2398 (estimated) PR2354
L2 On-board Cache: 256kB ECC synchronous write-back
Front Side Bus Speed: 2x 149MHz (298MHz data rate) / 2x 146MHz (292MHz data rate)
Technology Support
SSE2 Technology: No
Hyper-Threading Technology: No
CPU Multi-Media Benchmark
[hr]
Benchmark Results
Integer aEMMX/aSSE: 8962it/s / 8113
Floating-Point aSSE: 9937it/s / 8980
Test Status
SMP Test: No
SMT Test: No
Rendered Image Size: 860x570
Processor(s)
Speed: 1.67GHz / 1.60GHz
Performance Rating: PR2439 (estimated) / PR2338
Front Side Bus Speed: 2x 152MHz (304MHz data rate) / 2x 145MHz (290MHz data rate)
Technology Support
MMX Technology: Yes
SSE Technology: Yes
SSE2 Technology: No
Extended AMD MMX Technology: Yes
3DNow! Technology: Yes
Extended 3DNow! Technology: Yes
File System Benchmark
[hr]
Hard Disk (C:)
Benchmark Results
Drive Index: 12773kB/s / 9701kB?s
Disk Status
SMP Test: No
SMT Test: No
Windows Disk Cache Used: No
Use Overlapped I/O: Yes
Command Queue Depth: 4 command(s)
Test File Size: 256MB
File Server Optimised: No
Benchmark Breakdown
Buffered Read: 44 MB/s / 85MB/s
Sequential Read: 16 MB/s / 14MB/s
Random Read: 6 MB/s /3814 kB/s
Buffered Write: 29 MB/s / 28MB/s
Sequential Write: 17 MB/s /9 MB/s
Random Write: 10 MB/s /3531 kB/s
Average Access Time: 7 ms (estimated) / 12 ms (estimated)
Drive
Drive Class: Fixed
Total Space: 16.0GB / 15.6GB
Free Space: 14.6GB, 91% / 14.0GB, 90%
CD-ROM/DVD Benchmark
[hr]
Wxpvol_en (D:)
Benchmark Results
Drive Index: 76214kB/s / 10064kB/s
CD-ROM/DVD Status
SMP Test: No
SMT Test: No
Windows CD-ROM/DVD Cache Used: No
Disc Tested: Data CD/DVD
Test File Size: 73MB
Benchmark Breakdown
Drive Technology: 434x CD speed / 76x CD Speed
Track Speed: 229188 RPM (estimated) / 40134 RPM (estimated)
Buffered Read: 75 MB/s / 15MB/s
Sequential Read: 75 MB/s / 13MB/s
Random Read: 74 MB/s / 5 MB/s
Average Access Time: / 31 ms (full stroke, estimated)
Memory Bandwidth Benchmark
[hr]
Benchmark Results
RAM Bandwidth Int Buffered aEMMX/aSSE:1941MB/s / 411MB/s
RAM Bandwidth Float Buffered aEMMX/aS:1844MB/s / 339MB/s
Int Buffered aEMMX/aSSE (Integer STREAM) Results Breakdown >
Assignment: 1938MB/s / 414MB/s
Scaling: 1945MB/s / 415MB/s
Addition: 1945MB/s / 411MB/s
Triad: 1937MB/s / 407MB/s
Data Item Size: 8-bytes / 64-bits
Buffering Used: Yes
Offset Displacement Used: Yes
Bandwidth Efficiency: 163% (estimated) / 35% (estimated)
Float Buffered aEMMX/aSSE (Float STREAM) Results Breakdown >
Assignment: 1948MB/s / 405MB/s
Scaling: 1862MB/s / 322MB/s
Addition: 1790MB/s / 309MB/s
Triad: 1779MB/s / 322MB/s
Buffering Used: Yes
Bandwidth Efficiency: 155% (estimated) / 29% (estimated)
Test Statistics
Memory Used by Test: 128MB
SMP Test: No
SMT Test: No
System Chipset
Model: Intel Corporation 82443BX/ZX 440BX/ZX CPU to PCI
Bridge (AGP Not Implemented)
Front Side Bus Speed: 2x 149MHz (298MHz data rate) / 2x 145Mhz (290MHz data rate)
Max. Bus Bandwidth: 2384MB/s (estimated) / 2320MB/s (estimated)
Logical/Chipset Memory Banks
Bank 0 Setting: 32MB EDO / 16MB EDO
Bank 1 Setting: 32MB EDO
Bank 2 Setting: 32MB EDO / 16MB EDO
Bank 3 Setting: 32MB EDO
Bank 4 Setting: 32MB EDO / 16MB EDO
Bank 5 Setting: 32MB EDO
Bank 6 Setting: 32MB EDO / 16MB EDO
Bank 7 Setting: 32MB EDO
Memory Bus Speed: 1x 149MHz (149MHz data rate) / 1x 145MHz (140MHz data rate)
Max. Memory Bandwidth: 1192MB/s (estimated) / 1160MB/s (estimated)
Instruction Set Support
MMX Technology: Yes
SSE Technology: Yes
SSE2 Technology: No
Cache & Memory Benchmark
[hr]
Benchmark Results
2kB Blocks: 13317MB/s / 12341MB/s
4kB Blocks: 14096MB/s / 13051MB/s
8kB Blocks: 14428MB/s / 13431MB/s
16kB Blocks: 12308MB/s / 11478MB/s
32kB Blocks: 10234MB/s / 9532MB/s
64kB Blocks: 9488MB/s / 8915MB/s
128kB Blocks: 6170MB/s / 5578MB/s
256kB Blocks: 4803MB/s / 2953MB/s
512kB Blocks: 1053MB/s / 993MB/s
1MB Blocks: 904MB/s / 772MB/s
4MB Blocks: 898MB/s / 744MB/s
16MB Blocks: 896MB/s / 601MB/s
64MB Blocks: 893MB/s / 325MB/s
256MB Blocks: 0MB/s / 0MB/s
1GB Blocks: 0MB/s / 0MB/s
4GB Blocks: 0MB/s / 0MB/s
Float iSSE Cache/Memory Results Breakdown >
Data Item Size: 16-bytes / 128-bits
Buffering Used: No
Test Statistics
SMP Test: No
SMT Test: No
Processor(s)
Speed: 1.67GHz / 1.61GHz
Performance Rating: PR2437 (estimated) / PR2354 (estimated)
Internal Data Cache: 64kB synchronous write-back
Technology Support
SSE Technology: Yes
SSE2 Technology: No
System Chipset
Front Side Bus Speed: 2x 151MHz (302MHz data rate) / 2x 145MHz (292MHz data rate)
Max. Bus Bandwidth: 2416MB/s (estimated) / 2336MB/s (estimated)
Memory Bus Speed: 1x 151MHz (151MHz data rate) / 1x 146MHz (146MHz data rate)
Max. Memory Bandwidth: 1208MB/s (estimated) / 1168MB/s (estimated)
Network/LAN Bandwidth Benchmark
[hr]
WORKGROUP
RON-W2KSRV
Benchmark Results
Network Bandwidth: 31500kB/s / 9000kB/s
Host >
IP Address: 192.168.245.1 / 210.220.230.100
Benchmarks Breakdown >
Average Latency: 1ms
Min/Max Latency: 1 - 5ms / 1 - 3ms
Transfer Rate: 31500kB/s / 9000kB/s
Final results:
CPU Arithmetic Benchmark: VMWARE
CPU Multi-Media Benchmark: VMWARE
File System Benchmark: VMWARE
CD-ROM/DVD Benchmark: VMWARE
Memory Bandwidth Benchmark: VMWARE
Cache & Memory Benchmark: VMWARE
Network/LAN Bandwidth Benchmark: VMWARE
User avatar
DosFreak
Postby Snover » 2002-9-01 @ 21:04
Well there you go, but for the love of god, STOP USING DASHES FOR HORIZONTAL RULES! There is an [hr ] option you can use!! It's a really bad hack care-of yours truly, but it works.
Snover
Re: VMWARE v3.1.1 Build 1790 versus VPC v5.0 Build 350 Benchmarks
Postby Nicht Sehr Gut » 2002-9-02 @ 00:49
DosFreak wrote:VMWARE v3.1.1 Build 1790/VPC v5.0 Build 350 Both PC's using 16GB Expanding images.
Yeah, but VmWare's cheating (Virtualizing instead of emulating). :P
User avatar
Nicht Sehr Gut
Postby Snover » 2002-9-02 @ 04:01
Who cares? It works better. :D
Snover
Postby Nicht Sehr Gut » 2002-9-02 @ 07:29
Snover wrote:Who cares? It works better. :D
Phbbt :P Says you... If your talking high-level servers maybe. Game compatibility makes VPC look like a dream. They support Direct-X in the emulation yet?
User avatar
Nicht Sehr Gut
Postby Snover » 2002-9-03 @ 02:28
Why would you need DirectX support? Most (all?) games that use DirectX can use "real" Windows ... can't they?
Snover
Postby Nicht Sehr Gut » 2002-9-03 @ 06:52
Snover wrote:Why would you need DirectX support? Most (all?) games that use DirectX can use "real" Windows ... can't they?
Well, that depends on who you ask. Some say "most 2D games" work, others have said anything with Direct-X choked. Last I heard it was projected for future revisions because Direct-X has become so obligatory for Windows that they're concerned common applications will start breaking (due to no proper Direct-X support) because of it.
Update: Apparently there's _some_ kind of Direct-X support, but I can't find anything official. The FAQ below seems closest to an answer. They don't inspire confidence:
Q: Why do buttons and icons appear as black squares in Windows NT or Windows 2000 after running a virtual machine in Direct Draw? A: Going to full screen in a virtual machine that is configured to use Direct Draw graphics may cause buttons and icons to appear as black squares in Windows NT or Windows 2000. Rebooting is required to return the appearance of the buttons and icons to normal.
Q: Do you support Direct Draw/DirectX graphics?
A: VMware provides very limited support for Direct Draw through the HEL (Hardware Emulation Layer) in Direct Draw. Many Direct Draw applications will not run in a virtual machine.
Microsoft Windows 95, Windows 98 and Windows NT's Direct Draw can emulate DirectX/Direct Draw support for device that does not support Direct Draw (such as VMware's virtual SVGA adapter). This is done in the HEL (Hardware Emulation Layer) within Direct Draw. This emulation may be slow and/or unreliable.
Q: Such-and-such application produces terrible sounds or no sound at all, or aborts or behaves in other weird ways when trying to use the sound device.
A: Don't use that application, or use it with sound turned off if possible.
Maybe DosFreak can shed some light on this.
User avatar
Nicht Sehr Gut
Postby DosFreak » 2002-9-03 @ 13:15
The basica translation:
DirectDraw Supported
Direct3D is not.
and of course most 3D games and even 2D games nowadays use Direct3D
User avatar
DosFreak
Postby Stiletto » 2002-9-04 @ 01:42
These results are really hard to read. Where are the VPC results?
do the Fandango!" - Queen
Stiletto
User avatar
Stiletto
Postby DosFreak » 2002-9-04 @ 03:39
Vmware first / VPC second
Seperated by the "/"
User avatar
DosFreak
Postby Stiletto » 2002-9-04 @ 17:21
Ah. I get it now. Wouldn't a table work better? (Colin?)
Stiletto
User avatar
Stiletto
Postby Snover » 2002-9-05 @ 02:05
eh..eh..eh.. it was hard enough to get horizontal rules to work and that was a cheap hack, but I'll try. :)
Test of it:
[tablecell]This is a table cell.
Table table table
cell cell cell
bla bla bla
ya ya ya[/tablecell][tablecell]So is this.[/tablecell]
This is not in a table.
Table table table
cell cell cell
bla bla bla
ya ya ya[/tablecell][tablecell=top]So is this, but it's vertical-align : top.[/tablecell]
Snover
Return to PC Emulation
Who is online
Users browsing this forum: No registered users and 2 guests
