First post, by CoreDuo
I searched for a good long while on the forum for something somewhat relevant to this but I was coming up empty.
I have this motherboard that I acquired off eBay and was considering using an AWE32. I will need to buy a power supply because unfortunately, I don't have any spares. After looking around on Newegg, I became curious about any reasons that newer power supplies wouldn't work on this board. I then noticed a something that was eliminated in the ATX v1.2 spec, the lowly -5V rail. Digging around some more, I found out that this was used for (old?) ISA cards. I'd read generalizations that "modern" sound cards either didn't use this rail at all or derived it from the -12V rail.
My questions here is:
Is there a specific revision of ATX power supply I need to look for so that it does have a -5V rail so that I can use something like an ISA Soundblaster 16, AWE32, or the like?
I also realize the board has PCI slots but I already have ISA sound cards so I'd like to try and use those first.
Thanks! 😀
http://coreduo.me.uk
Reply 1 of 10, by retro games 100
You're in luck. You don't need any special PSU. Your old Creative ISA soundcards don't need the -5V rail. There is a really old 8-bit Creative SoundBlaster that needs it, but I can't remember the exact model number. However, it's not on your list of old ISA hardware. I believe that the old Roland LAPC-i also needs the -5V rail.
However, there is a really nice modern quiet efficient ATX PSU you can buy, that still includes the -5V rail! It's here. They've even got some left in stock. I've bought them from here before, and so I can recommend the seller and the product.
If you want to use a new ATX PSU with an old AT power socket on an old mobo, that's easy too. Here is an adapter on ebay. I've bought them from that seller before, and I can recommend them.
Reply 3 of 10, by memsys
Sorry for digging this up but what was the -5 volt line used for ? All i know is that it's used by some isa cards.
Can i use this motherboard without the -5 line safely ?
Also that were to happen if i accidentally put in a isa card that used the -5 line ?
Reply 4 of 10, by Great Hierophant
-5v is only used on the expansion bus, so your motherboard should work just fine without it.
-5v is used by the Roland LAPC-I, the Sound Blaster 2.0, some ISA VGA cards and memory expansion adapters
The system may freeze if you put a card in that uses -5v until you pull it out.
Reply 7 of 10, by sklawz
hi
i can't help specifically but refer to this page:
http://pinouts.ru/Slots/ISA_pinout.shtml
if a card uses B5 on the solder side (reverse) then
you have a requirement for -5v.
it would seem that ancient DRAM boards require
it and it's said also very old NEC floppy controllers.
i can't say i that i have anything that uses it although
B5 is connected on a mediavision jazz16 card i have.
bye
edit:
if this is the card:
http://www.yjfy.com/images/oldhard/sound/MPU-IPC-T_1.jpg
then it would appear not to use B5
Reply 8 of 10, by megatron-uk
I'm looking at my MPU-IPC-T in front of me now and it has the pad for B5 (actually my version has every pad in place and uses a 25-way D-connector for the breakout), but it's not actually connected to any traces.
https://www.target-earth.net
Reply 10 of 10, by buckrogers
sklawz wrote:
hi
Thanks very much.
On a closely related topic, modern PSU's that may be considered for our old school rigs include:
1. Nexus NX-3500 (has -5v rail) (end of life / discontinued)
2. Nexus Value 430 (no -5v but similar max current demands on all three +ve rails)
3. Lowest power Seasonic S12II Bronze is also worth a look.
