First post, by F_Slim
Hi there,
I have a new PC running Windows 7, but I want to use my old controller, which is an old CH Throttle control. This thing has a bunch of programmable buttons to simulate keyboard inputs, and is connected to the PS/2 between keyboard-plug and the PS/2 port on the PC.
In principle everything works, all axis of the Throttle and attached Joysticks work, and also the currently assigned buttons on the Throttle work fine.
Now the problem: the configurator-software to change the buttons is a DOS program. Windows 7 (64 bit) refuses to start the software no matter what.
In DosBox I can load the program, but it does not recognize the Throttle.
I assume that there is no direct "connection" between DosBox and the PS/2 port?
Does anybody know a workaround or solution to this?
Thanks in advance!
F_Slim
