First post, by Ailicec
Hi Everyone,
I picked up a 386-33 motherboard on Ebay to run old software and have a testbed for old hardware. Its one of the American Megatrends Baby Screamers (386 Baby Screamer Series 42, slightly different than the ones you can find at stason.org), and I was really hoping it would turn out to be a good find.
Unfortunately all it will do is beep a POST code indicating the A20 problem. I switched memory out, no change. Since this board doesn't have a discrete keyboard controller, I'm guessing the problem is on the CHIPS F82C711 peripheral controller. I'm not entirely afraid of replacing that PQFP chip, but finding it is going to be awfully hard. Also I could be wrong on which chip - the datasheet for the CHIPS doesn't mention the keyboard, and there are two other VLSIs chips on it, and one completely unlabled 100 pin QFP.
The board also had some bent header pins, no big deal, and a sliced PCB trace, which I fixed (poorly but it should work, also I think its to an ISA slot, which is not critical at this point). Probably what happened with this board is it failed 15 years ago, got thrown in a pile, then dug up to dump on the ebay market.
I know the chances are slim, but it seems a shame to dump a nice board. Any ideas?
