First post, by SavantStrike
I'm a bit confused at the moment. I know Pentium MMX chips are VRE, but I'm at a loss as to what the proper voltage for the chip is. The back side of my 233 MMX says core voltage is 2.8V, but my motherboard only supplies 2.73V or 2.91V. Some of the material I've read shows that the current the chip draws is calculated at 2.9v, and not at 2.73. Furthermore, it appears the voltage range for the Pentium MMX is between 2.7 and 2.9 volts.
So does this chip run at 2.91V, or 2.73V? It makes a pretty big difference too as the motherboard I use has VRM's that can supply a maximum of 7A. With a TDP of 17W, that means the chip would draw ~5.8A at 2.91V and ~6.2A at 2.73V (alhough oddly enough the data I'm reading says 6.5A, but that can't be right). I'm not happy about that as the VRM's got too hot to touch with a Pentium 133 non mmx (3.4A). Admittedly, this is with no airflow, but I'm still concerned.
Additionally, I got my figures for TDP from this site. It's got all sorts of handy data for all kinds of chips. Amperage is provided, but the 2.73v amperage was not (but V= IR so no worries 😀 ).
