First post, by endre1952
I'm looking for the driver disk for the S-MPU-II-AT midi interface card, especially "SMPUENA.EXE", which is needed to use the card in MS-DOS.
Hello Endre,
I saw your post at queststudios, good to know that you finally got the driver(s).
"Ita in vita ut in lusu alae pessima iactura arte corrigenda est."
Yes, I've only been able to test it in my 386 SX-40MHZ, and there are issues with certain games. I wonder if perhaps in a faster computer...After all, it was one of the last midi ISA cards, made around 1998 I think.
This card does support intelligent mode, at least to a certain degree.
It supports Intelligent mode. It just has no IRQ2 which is needed for some games.
Are you sure IRQ2 isn't that same as IRQ9? Weird, I know, but some sources say so. In the old days, my SCC-1 jumpered to IRQ2 worked with software supposedly using IRQ9. The games I've tried all worked, just some didn't work properly.
IRQ2 is IRQ9 since PC AT
1+1=10
The S-MPU-II does support IRQ9. Could there a problem with that? I'm having issues, but I'm still thinking that this card should be tested in something faster than a 386 (which is my only computer with ISA slots at the moment).
