First post, by AdamP
Hi,
I hope this is the right place.
I have a SBLive! (CT4760) which works fine in Windows. The SB16 Emulation works fine in pure DOS, but I cannot for the life of me get it to work at all, whatsoever, in Windows. The driver never installs automatically and a manual install doesn't work. I am using Windows 98SE.
I am using the drivers (yes, I'm using the VXD drivers, although I had a hard time persuading Windows to use them instead of the WDM drivers) that came on the CD (which curiously, also had Audigy drivers and software on it, despite being a Live! CD). I think I did manage to get it working once (in an old installation of Windows 95) by using older drivers, but then I couldn't use some of the advanced features, and I don't think the software recognised it.
Autoexec.bat:
@if exist C:\WININST0.400\SuWarn.Bat call C:\WININST0.400\SuWarn.Bat
@if exist C:\WININST0.400\SuWarn.Bat del C:\WININST0.400\SuWarn.Bat
SET BLASTER=A220 I5 D1 H5 P330 T6
SET CTSYN=C:\sbdos
rem lh C:\windows\emm386 auto
C:\sbdos\sbeinit
rem C:\sbdos\sbeload
rem LH C:\windows\command\MSCDEX.EXE /S /D:mscd001
rem lh C:\mouse\mouse.com
;SET PATH=%PATH%;C:\PROGRA~1\BORLAND\DELPHI5\BIN;C:\PROGRA~1\BORLAND\DELPHI5\PROJECTS\BPL
lh mode con codepage prepare=((850) C:\WINDOWS\COMMAND\ega.cpi)
lh mode con codepage select=850
lh keyb uk,,C:\WINDOWS\COMMAND\keyboard.sys
Config.sys:
dos=high,umb,auto
device=C:\windows\himem.sys /testmem:off
devicehigh=C:\windows\command\emm386.exe noems
devicehigh=C:\windows\setver.exe
;devicehigh=C:\windows\command\oakcdrom.sys /D:mscd001
devicehigh=C:\WINDOWS\COMMAND\display.sys con=(ega,,1)
Country=044,850,C:\WINDOWS\COMMAND\country.sys
ctsyn.ini:
[ctsyn.drv]
OPLPort=388
MPUPort=330
SBPort=220
SBIRQ=5
SBDMALO=1
SBDMAHI=5
SBEnable=true
JoyPort=200
JoyEnable=true
Waveset=C:\sbdos\default.ecw
PCIPort=1420
PCIIRQ=10
[SBEINIT]
CONFIG=SBESET.CFG
[SBESET.CFG]
SBPORT=220
MPUPORT=330
SBIRQ=5
SBDMALO=1
SBDMAHI=5
OPLPORT=388
SBENABLE=TRUE
JOYPORT=200
JOYENABLE=TRUE
WAVESET=C:\SBDOS\DEFAULT.ECW
PCIPORT=1420
PCIIRQ=10
Any help would be appreciated.
Thanks
