Reply 20 of 20, by Markk
- Oldbie
Oh, and about the battery, I would suggest to use a battery holder for 3 AAs. That way you can change them in an easy way when needed. I think you have to connect it to the header next to the CMOS chip. Pin 1 should be positive and pin 4 negative.
