First post, by theelf
Hi, i don´t have any idea what happen with my ET4000AX that can´not do 1024x768x256 on a TFT monitor
In a CRT works ok, i think maybe is because this card do in a interlaced mode?
My old Trident 8900C works perfect in 1024 on this TFT 🙁
I spend some money in this ET4000, just for keep using the old trident 🤣
Some ideas?
Reply 2 of 10, by theelf
Is funny, logic say that the ET4000AX is the shit compared with the 8900C, but the trident can do 1024x768 in my TFT, and the 4000 don´t....
Then for now, yes, sadly, the trident still rocks for me
I really want to know if is possible to get 1024 in a normal way in the ET4000
Reply 3 of 10, by Markk
It has happened to me also. Maybe it has to do something about the refresh rate supported by the monitor. Try switching to 60Hz while you have the CRT monitor connected, and then try the TFT. How much memory does the ET4000AX has?
Reply 5 of 10, by theelf
I don´t know how to swicth to 60hz in msdos or 3.1
I tried scitech vesa 3.0, but don´t find any option for 1024x768x8 60hz
The ET4000 has 1mb
What program do you use to test the 1024x768 mode?
I try different programs
In msdos,
qpv (image viewer)
neopaint
Win3x
svga drivers
ET400AX drivers
The same results, 800x600 is ok, but when i change to 1024 "out of sync"
In the CRT the 1024 mode in the trident is perfect, clear. The Tseng do a 1024 interlaced horrible
Oh god, i spend 2 euros in the Trident, and 25 in the ET4000AX....
Reply 7 of 10, by theelf
Thanks for reply
For sure, i think same, this must be the reason, but i don´t understand how a cheap trident can, and a ET4000AX that i read in every place is a great card, can´t
Must be some kind of way to solve this problem...
The only solution i know for now, is sell it, and buy another card.... ;(
Reply 8 of 10, by elianda
I actually use VMODE which was already discussed in this thread:
VESA Fix Utility Listing (for old video cards)
Download:
download.php?id=5159
Before you complain about the interlaced mode for 1024 mode - this was the first more or less standard this mode for SVGA going back to the 8514/A introduced in 1987 by IBM. So while the ET4000 goes for the standard, the Trident go for frequencies old CRTs could not handle.
Youtube Channel
Reply 10 of 10, by theelf
I actually use VMODE which was already discussed in this thread: viewtopic.p...ight=vmode Download: download.php?id=5159 […]
Download:
THANK YOU!!!
ok, the vmode file you say don´t work on my ET4000 card
But looking for vmode in google, i end up finding this file
http://www.grex.org/~keesan/vmodetsg.zip
The dos command is
vmode 72m
This give the 1024x768 non-interlaced * that what i was looking
Oh by the way, the trident 8900C is a little faster than the Tseng in Win3x !! 🤣
Now that i have Win3x and picture viewers working in 1024, is time to go for run Quake in the 386....
