First post, by elix
I had this rig for several years, but did not bother with it until now.
Its a small AMD 286 12mhz.
around 2mb ram setup nags for the correct amount.
WDC Paradise somthing ISA VGA graphics. Attached to the ISA controller board that houses the CPU and ram.
Quantum Prodrive 40mb
Scribe somthing 40MB via expansion bay in the front.
and 1.44mb floppy
Thing is i cant seem to get the computer to detect my HDDs after the cmos battery have failed.
I know the drives works i have tested them in a other system. And it got stuff from 1995 on it. Passes scandisk etc.
But when installed in the v286 it just wants to boot to floppy, and it works ive run ms dos via a disk and played som street rod 😁
The bios has 2 settings for HDD, Automatic and manual. Ive tryed both.
Ive found the settings for the hdd so ive changed it to a manual "type 34" but it does not work, it just wants to boot to floppy.
The Bios settings are few, and no boot order setting.
While in DOS, trying to use fdisk it says i have no fixed disks.
There is not mutch on google on this computer.
So i turn to you guys!
Reply 1 of 10, by Norton Commander
I'm not familiar with that particular model PC but most 286-386-486 of that era didn't autodetect drives like modern machines. You had to manually enter all drive information (heads/cylinders etc.) for them to work which is why it sucked when your CMOS battery died. Usually the drives came with some spec sheet with all that info.
I used to own a pirated copy of MH-IDE (Micro House IDE util) that ran off a floppy and would auto detect most IDE drives and even write this info to CMOS. Even when it couldn't write it to CMOS I would just copy the info to a piece of paper then enter it manually.
Basically you will have a few options:
1) Google the drive models for the necessary info.
2) Find an equivalent utility that can read the drive info and display it on screen or write to to CMOS for you. Maybe someone else here can recommend something equivalent to MH-IDE.
3) Find a Pentium era PC with built-in IDE - when you connect your drives they should be auto-detected. Go into the CMOS and copy the drive values onto a piece of paper. Reconnect your drives to your 286 and enter the information obtained into CMOS. Make sure you have replaced the CMOS battery or you will have to enter this info each time you reboot your 286 PC.
Reply 2 of 10, by elix
Thing is that it has automatic mode for HDDs and manual.
ive got the drive settings from : http://www.computerhope.com/hdquantu.htm
Its the PRODRIVE 40 model. And i have tested it on my advance/ml pentium board where its working fine.
In the bios the manual settings refere as "TYPE" eg the drive i have is a type 34 that info matches my drive parameters.
I will try somekind of IDE util as u wrote.
Also it is possible that the IDE controller has died? or is it just forgetting my settings cuz the battery is disscharged? I get a Error message every time i hard reset or soft even just ctr alt del reset the computer. But the time and all other settings are still saved.
Reply 3 of 10, by Norton Commander
It is possible that the IDE controller has died but the likely culprit would be the battery. Change that before you do anything else.
Make sure you have the jumpers on the drives set correctly AND in the correct position on the IDE cable.
Plug the drives into the other PC and write down all the HD info from the CMOS. Plug in 1 drive at a time into the 286 and enter the info you just wrote manually in the drive settings and see if it picks up the drive. I've had better luck on older machines manually entering drive info than choosing one of the predefined type listed in the CMOS.
Reply 4 of 10, by elix
Thanks for the info, i will post when i get the new battery. I also getting a other ISA IDE card so i can test whit that.
DATA NOVA 486DX
Cx5x86 100GP @ 120Mhz | noname SIS AT mobo | 2x8MB FPM | Tseng Labs ET6000 PCI 2.5MB | Creative AWE64 Value | 2x8GB WD Caviar.
MS-DOS 6.22 / Microsoft Windows 95b
Reply 5 of 10, by shspvr
Is your a MFM Hard Drive or Standerd IDE Hard Drive
Dose the Hard drive spin up?.
Have you try unplug the power to hardddrive pull the cable and remove IDE card re-seat the card and plug everthing back in.
Reply 6 of 10, by elix
Yes the drive work. Ive installed it on my pentium setup, And i booted dos from it. its working just fine. Its a standard IDE drive.
I will post some pictures of the computer, its very small and the CPU and memory are on a ISA board that also houses the VGA board.
DATA NOVA 486DX
Reply 8 of 10, by elix
Ive tryed all the settings 😁 no go.
It seems that its the cmos battery that makes this error. Ive saw on a french forum a user whit the same problem after the battery died.
The battery is soldered on the board, so we will see how that goes 😁
DATA NOVA 486DX
Reply 9 of 10, by legacynight
Are we talking about an SBC; Single Board CPU ; I might have the same board: Victor Technologies 286 16/S - vga onboard - 30pins memory - if that is correct? - Unfortunatly i don't have a working keyboard - as the AT/XT keyboard isn't recognized beyond the caps/scroll/num - i managed to upgrade the board to 8Mb 30pin - but the board slept a bit to long and the settings are off
Please let me know ; i still have some 30pin memories 😉
http://i1248.photobucket.com/albums/hh498/her … ts/100_1942.jpg
http://i1248.photobucket.com/albums/hh498/her … ts/100_1937.jpg
just found: http://www.cbronline.com/news/tandy_to_keep_v … dy_product_line
From out the Soil we crawled upon
back to those roots we reach.
Reply 10 of 10, by elix
Yeah that is the one i belive!
Ive gotten the new realtime thingy. but i havent desolder the old one yet due to i dont have the proper tools 😜
DATA NOVA 486DX
