First post, by nforce4max
- l33t
For anyone here that has anything to do with modern rigs that needs or wanting a new power supply or builds/upgrades clients rigs avoid this brand. Their customer support is liquid crap, they take forever to reply let alone fallow through with rma.
My unit that being an hale90-1000-m kicked the bucket this morning and testing showed that the phase(s) that supplied power to the board and cpu failed. Over the past few days I noticed some coil whine while multiboxing wow. One phase failed so I changed to the second 8pin eps and it worked for a while then it finally died all the same. I look through the vent and sure enough the inductors don't look all that healthy with the insulation having a dark color. As for the rest look online as I am not the only one.
/rage face
