First post, by Soupdragon
Which order should I have the sound card setup lines in my dos 6.22 autoexec.bat file
I have 2 sound cards a jumpered sb32 with real opl3 and a gravis ultrasound max plus a mpu-ipc-t midi interface.
The reason I ask is some times I will install a game and go to set up the sound and as i go through the sound blaster set up options it will default to odd settings not the standard a220, irq 5 and dma 1.
Below is my autoexec.bat at the moment any other tweaks are welcome:
@ECHO OFF
LH C:\DOS\SMARTDRV.EXE /X
LH C:\DOS\MSCDEX.EXE /D:CDROM1 /L:E
LH C:\DOS\KEYB UK,,C:\DOS\KEYBOARD.SYS
LH C:\DOS\DOSKEY.COM
LH C:\DRIVERS\CTMOUSE\CTMOUSE.EXE /P
PROMPT $P$G
SET DIRCMD=/O
SET PATH=C:\ULTRASND;C:\DOS
SET TMP=C:\TEMP
SET TEMP=C:\TEMP
SET ULTRASND=240,3,3,7,7
SET ULTRADIR=C:\DRIVERS\ULTRASND
SET ULTRA16=34C,0,0,1,0
C:\DRIVERS\ULTRASND\ULTRINIT.EXE -DJ
SET SOUND=C:\DRIVERS\SB16
SET BLASTER=A220 I5 D1 H5 P300 E620 T6
SET MIDI=SYNTH:1 MAP:E MODE:0
C:\DRIVERS\SB16\DIAGNOSE /S
C:\DRIVERS\SB16\AWEUTIL /S
C:\DRIVERS\SB16\MIXERSET /P /Q
