8.176GHZ
First post, by nforce4max
http://en.expreview.com/2012/10/26/amd-fx-835 … 6ghz/24814.html
Not bad for all 8 cores.
Reply 2 of 13, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Slow?
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 7 of 13, by dosquest
...in 2036 people will be coming to this forum asking "hi can I run crisis 1 in windows 16" and all the "retro games" will be like metro 2033 and crisis.
Doom isn't just a game, it's an apocalypse survival simulator.
Reply 10 of 13, by dosquest
On a side note, did you really get your avatar removed lel? Damn that one was around for years, are the mods getting too picky now?
Reply 11 of 13, by Qbix
Rank DOSBox Author
DOSBox Author
You didn't consider the possibility that the lei changed it ?
Water flows down the stream
Reply 12 of 13, by sliderider
I never understood the point of these extreme overclocking experiments. I would think that the fastest overclock that you can get away with and still use the machine on a daily basis would be a whole lot better than 8ghz on liquid nitrogen, something that you would never be able to actually use for more than a few minutes at a time without spending a ton of money on coolant or destroying your CPU/motherboard.
I would be much more impressed with a much lower speed that is actually usable mounted in a case using high performance air cooling or even a liquid cooling system that is readily available to most people.
