First post, by bjorn_and
Hi!
I recently acquired an IBM XT-286. In that machine I found a Voyetra OP-400x card which I think is a 100% MPU-401 compatible, but I'm not sure.
Also, it's missing the breakout box.
So if anyone here can help me:
1. Is there anyone who knows if this card is MPU-401 compatible (I would think so)
2. Is it possible to build your own breakout box? I was thinking if I could use an MPU-401 breakout box which are readily available on eBay, but at least for early Roland MPU-401's, the breakout box is the actual MPU-401?
See attached images.
Thanks!
Björn Andersson
