Well theoretically it is 512MB, but I think it does have to do with banks and rows and double sided SDRAM, and the number of slots the particular model of mboard has, so in some cases you might not be able to take advantage of the chipset full capacities, due to stupid design or cost-cutting compromises, and depending on what ram sticks you have in hand.
Tetrium wrote:Ah, I assumed you already had it in your possession!
I'm inclined to believe it's a Socket 370 because the Socket 370 433Mhz Cel […]
Filosofia wrote:
Tetrium, is it the ZX chipset that inclines you to socket 370?
I realy have no way to know, unless I buy it first and check after 🙁
I'm inclined to believe it's a Socket 370 because the Socket 370 433Mhz Celerons are more common 😉
It also depends on what it will cost if it's worth it to buy it.
How much will it cost you?
Btw, I've run a Celeron 400 LX-based Socket 370 (also only supports the early Celerons) and it ran very well for what it was. The Celeron 370 boards are by no means bad or unstable. Just not that upgradeable 🤣
Filosofia wrote:Please correct me if I'm wrong , but what is the point of having a ZX chipset based motherboard with socket 370 if it can only run Celerons, wtf? 😲
It could be that a particular motherboard manufacturer already had a Socket 370 LX board which was selling well, but they ran out of chipsets to put on the boards.
So sk370 433MHz are more common... 😢
The total amount the seller is asking is €10, it includes:
the case, a very ugly one,
probably a flimsy psu, but one of those nonetheless
the ZX board,
the celeron 433 (slot 1 or socket 370 ? 😀 )
and its standard cooler (I expect)
32MB of unknown ram,
a mistery 8MB graphic card,
a sound card designated only by "16",
an 8,4 GB hdd of unknown rpm
the floppy drive
and a whopie 50x cd-rom
so 0.90 a piece ( is it optimist or self-ilusion? 🤣 )
