First post, by dosquest
Hey, I was wanting to relive some of my early early years and I was wondering if there were any still active BBS boards with file sharing, the whole enchalada, boards, files, other stuff...cough...
Reply 2 of 3, by Jorpho
There should be no shortage of them running on Telnet servers.
And no, there's really not much a BBS can do that an equivalent Internet service cannot do significantly better. I guess they might serve as a useful way to keep something private.
Reply 3 of 3, by Stull
There are still a lot of telnet ones out there.
If you want to telnet from a modern machine, I recommend SyncTERM:
http://syncterm.bbsdev.net/
Here's a fairly current list of Synchronet-based boards:
http://synchro.net/sbbslist.html
Here's some others:
http://bbs-scene.org/bbs_list.php
If you want to connect via an old DOS term program, you can use DOSBox and the built-in modem emulation, or you can play with Leif Bloomquist's BBS Server program:
http://www.jammingsignal.com/files/
It's intended for hosting, but it can also be configured for outgoing connections. If you have a DOS machine you can hook a null modem cable from it to a modern machine, use the BBS Server program to effectively convert the null modem into a network connection, and "Dial" (telnet) out from the DOS machine. Actually it works from basically any type of old machine with a serial port (Commodore/Amiga, Apple, etc).
