First post, by maw
hey,
does somebody know cd-rom models 4 to 10x which can be placed vertical in the case?
thx
M.
hey,
thx
M.
you'll need slot-insertion drive as opposed to tray, for vertical placing.
i must warn you though, whenever disc-jam happens, it would have more devastating effect on slot drive.
-fffuuu
There are vertical-capable tray-loading drives, they have little lugs around the edge of the tray to hold the disk while the tray goes in or out.
There is also caddy-loading drives, which work fine vertically as well.
No you don't. The vast majority (perhaps even all?) of the regular tray loaders work just fine vertically... I can't remember ever seeing one without the little retention tabs in the tray.
