First post, by Soupdragon
I installed the new geforce drivers so I could do 4x DSR in world of warcraft (I need this now MSAA has been removed). This works well but I find now I cant get dosbox or scumm vm to run full screen with the correct aspect ratio (black bars on the sides). Now it will always stretch the image.
With dosbox I tricked it by telling setting the output to 4k and that works (i get the bars). But I cant do that with scumm vm because there is no resolution selection.
Has anyone else come across this problem?
