First post, by sniperhgy
Dear All,
I followed the steps in the post Re: Guide: Windows 95 / 98 inside Dosbox - Accessing files on the host and mount CD images with mapped network drives, but it didn't work properly, I think it should be something wrong in my operation, could anybody help to explain some points in that post :
1) about step 5. : I added a NE2000 card in windows 95 and use the automatic address, now it can access the internet. Should I set a static IP-addres for it ?
2) about step 6.1 : I have installed the three software, Distributed Filesystem Client (dfs41w95.exe), Winsock 2.0 (w95ws2setup.exe), Dial Up Network 1.3 (MSDUN13.EXE), only install them is enough ?
Please provide your suggestions, thank you very much.
Best Regards,
Sniperhgy
Reply 2 of 6, by Sammy
i never tryed this, but if the only goal is to get access to cd-images inside windows95 in Dosbox:
I created a second IMG File (Data.img) and mount it in Dosbox.conf
So i mount Win95.IMG as Drive C and Data.IMG as Drive D in Dosbox.
Inside Data.img i can Store my CD-images with WinImage.
There is Space for 3 CD-Images in a 2GB Partition-Image.
I mount the Images with Daemon Tools.
If you like you can easily rename the Data.img if you use more then one. Or using a sperate IMG for each game.
Reply 3 of 6, by sniperhgy
collector wrote:
Keep in mind that Win9x is not officially supported in DOSBox.
Yes, my friend, you're right. But the version I'm using is DOSBOX SVN Daum, in this version, 500+MB img and Win95/Win98 had been supported.
Reply 4 of 6, by sniperhgy
Sammy wrote:
i never tryed this, but if the only goal is to get access to cd-images inside windows95 in Dosbox: […]
Hi Sammy,
Glad to see you again. Thank you very much for your suggestion, but in my opinion, the Dosbox doesn't support two hard disk drivers, please correct me if I'm wrong.
