First post, by superfury
It's both in 8-bit mode. Anyone can see why it won't detect the hard disks on AT, but it detects it on the XT(same settings used on both architectures):
https://bitbucket.org/superfury/unipcemu/src/ … ide.c?at=master
On the XT version it sends an identify command and properly reads all parameters, but on the AT it reads the first word, then gives up(The value read is 0x0440)? Anyone knows why the AT IDE BIOS simply aborts after that?
UniPCemu Git repository
