Windows 98 on Virtual PC
First post, by Muz
Hi, does anyone have tried put a midi file in a Virtual PC, running old OS, and try to play it, but it sounds like a weird sound. Does anyone knows how to fix that sound?
Also, why is the MIDI soundfont in the old OS, sounds different?
Reply 1 of 12, by leileilol
Not using VirtualPC helps. It has the worst OPL3 emulator ever
Reply 2 of 12, by Muz
You mean use VirtualBox?
Reply 3 of 12, by Jo22
Does it provide OPL3 emulation at all ?
Early versions of Connetix VPC started out with SB Pro support (dual OPL2 ?), so perhaps they modded it later on for OPL3's stereo mode
(in terms of addressing left/right channel) but haven't otherwise updated the OPL emulation itself (essencially still stuck with OPL2 registers/no 4-OP mode).
I'm just curious, since OPL2 games like SkyRoads don't sound all that bad in VPC.. ^^
Reply 4 of 12, by Muz
Try put any MIDI files in the VPC, it does play the MIDI, but it is quite bit distorted.
Reply 5 of 12, by SA1988
Use 86Box, it has a more accurate OPL3 emulation.
VirtualBox does not provide OPL3 emulation because it's not in their "priority" list.
Reply 6 of 12, by Muz
How do you install 86Box? I cannot install, because it needs d3dx9_43.dll.
Reply 7 of 12, by Jo22
Hmm.. Try to install the latest DirectX 9 runtime (web installer), it's still beeing updated I think.
.. or look for the D3DX9_29_dll_update / D3DX9_30_dll_update package.
Reply 8 of 12, by Muz
Ok, thanks.
Reply 9 of 12, by Muz
Can anyone tell me, where is the sample music, like Canyon.mid?
Reply 10 of 12, by Jorpho
Canyon.mid was included with Windows 3.1. You can probably find it for download in a million places with Google.
Reply 11 of 12, by Muz
I can't find Canyon.mid in Windows 3.1 Virtual PC.
Reply 12 of 12, by Aideka
https://lmgtfy.com/?q=canyon.mid
