The Landmark AT test BIOS says that the RTC Interrupt(Using the Periodic Interrupt) isn't working correctly ("1 FAILED" is reported). I see the timer (which runs at double the rate, at 64kHz to be able to create a square wave at 32kHz), which is timing out(generating interrupts) at increasing values from: 0x7F, 0x1FF, 0x7F, 0xFF, 0x7F, 0x3FF, 0x7F, 0xFF, 0x7F, 0x1FF, 0x7F, 0xFF, 0x7F, 0xFFF, 0x7F, 0xFF, 0x7F, 0x1FF, 0x7F, 0xFF, 0x7F, 0x3FF, 0x7F, 0xFF, 0x7F, 0x1FF, 0x7F, 0xFF, 0x7F, 0x7FF, 0x7F, 0xFF, 0x7F, 0x1FF, 0x7F, 0xFF, 0x7F, 0x3FF, 0x7F, 0xFF, 0x7F, 0x1FF, 0x7F, 0xFF, 0x7F, 0x1FFF, 0x7F, 0xFF, 0x7F, 0x1FF, 0x7F, 0xFF, 0x7F, 0x3FF, 0x7F, 0xFF, 0x7F, 0x1FF, 0x7F, 0xFF, 0x7F, 0x7FF, 0x7F, 0xFF, 0x7F, 0x1FF, 0x7F, 0xFF, 0x7F, 0x3FF, 0x7F, 0xFF, 0x7F, 0x1FF, 0x7F, 0xFF ... When testing the Real Time Clock Interrupt test of the BIOS.
Also a little question: what happens on an AT CMOS chip with 64 bytes of RAM installed, when bytes 64-127 are read? Does it simply wrap to 0-63? Or do they map to unexisting(always 0x00/0xFF)?
