First post, by ppgrainbow
I have problem getting the emulated network card with SLiRP instead of PCAP, the NE2000 ISA on the DTK 486 machine (AMD 486DX2 66MHz, 8 MB RAM, Phoenix S3Trio 64 w/1 MB VRAM).
I installed the Arachne v1.97 and tried to configure the IP address to use 10.0.2.15, 10.0.2.2 for the Gateway and 10.0.2.3 for the DNS as well as Boot/DHCP.
When I select Boot/DHCP, Arachne wouldn't even initalise the TCP/IP at all.
Here's a screenshot of the problem that I've been encountering:
27.14 KiB
Network problem...
The guest OS that i have installed is MS-DOS 5 and Windows 3.11 (no workgroup support).
Is there a way how this can be fixed?
Reply 3 of 17, by SA1988
ppgrainbow wrote:
SA1988 wrote:
use PCAP instead of Slirp.
I tried to use both WinPCap and Win10PCap. Neither of them worked. 🙁
SA1988, have you tested networking under 86Box using PCap on your PC?
Yes, works fine (WinPCap only, not Win10PCap).
Reply 5 of 17, by ppgrainbow
Battler wrote:
I have personally tested Win10PCap (since I'm using Windows 10), and it works.
I'll test it using a Damn Small Linux Distro to see if networking works with Win10PCap since I'm using Windows 8.1.
Update: I managed to boot the DSL linux distro off of the ISO on the ASUS P/I-5541P4XE machine and ended up using the Phoexnix S3 Trio 64 card with 2 MB RAM. The machine has the capability to boot off of the emulated CD-ROM.
I used DHCP when I set up the networking and when I tried to access the Damn Small Linux, I wound up getting a Server not found error:
123.27 KiB
DSL Bon Echo - Server not found
Any idea what could be wrong when I use Win10Pcap and setting the network type to PCap?
Reply 7 of 17, by ppgrainbow
Battler wrote:
- ppgrainbow: Could you PM me your 86box.cfg file? Because I'd need to look at your configuration to see what's wrong. I have a few ideas but I need to know to be sure.
I'll privately note you with the configuration of what I have right now.😀
Reply 8 of 17, by ppgrainbow
Problem solved! 😀
I updated to build 472 of 686B0x [07ffe37] and in the AUTOEXEC.BAT file, I simply changed line 19 to read LH NE2000 0x60 3 0x300.
0x300 is the address and the 3 is the IRQ that I'm using to emulate the ISA version of the NE2000 network card. It's easier to use SLiRP for now, because PCap isn't working too well...though I could be wrong.
Reply 9 of 17, by Sammy
I installed Win95 in 86box 1.20.
Network Card ist RTL8029 and Drivers are installed.
WinPCap is installed (Host system is Win7 64bit)
But win95 says it cant get a IP from DHCP so i think network is not working.
Also the Homepage of 86box say: PCap needs manual configuration...
What manual configuration is needed ?
Reply 10 of 17, by ppgrainbow
Sammy wrote:
I installed Win95 in 86box 1.20. Network Card ist RTL8029 and Drivers are installed. […]
Please use the stable version of 86Box. 😀
Reply 11 of 17, by Sammy
yes, i use the latest build. (optimized for core2)
i try with DHCP and with 192.168.178.19. 255.255.255.0 (86box)
Host has 192.168.178.4
Ping the Router with ping 192.168.178.1
no response when pinging from 86box, from Host it works.
In 86box.cfg i set: networkinterface=1
I am searching for etherlist.exe too.
This Tool should show the interface Number of the Host Lan Ethernet Interface.
PS. in Dosbox Lan Interface is 1 (ATHEROS........)
Dosbox uses WinPCap too, right? Cause in Dosbox Networking works.
Reply 12 of 17, by ppgrainbow
Sammy wrote:
yes, i use the latest build. (optimized for core2) […]
If WinPCap doesn't work, use SLiRP. 😀
Reply 14 of 17, by Sammy
Here is my 86box.cfg
gameblaster = 0
gus = 0
ssi2001 = 0
voodoo = 1
buslogic = 0
netinterface = 1
netcard = ne2kpci
pcap_device = \Device\NPF_{444C8E2B-183F-4322-8F14-AE71EFF2B2E7}
model = 430vx
cpu_manufacturer = 0
cpu = 3
cpu_use_dynarec = 1
cpu_waitstates = 0
gfxcard = mach64x
video_speed = 5
sndcard = sb16
cpu_speed = 0
has_fpu = 0
disc_a = C:\Users\Core2\Desktop\Win98Bootdiskette.IMG
disc_a_writeprot = 0
disc_b =
disc_b_writeprot = 0
disc_3 =
disc_3_writeprot = 0
disc_4 =
disc_4_writeprot = 0
hdd_controller = none
mem_size = 98304
cdrom_1_host_drive = 0
cdrom_1_enabled = 1
cdrom_1_sound_on = 1
cdrom_1_bus_type = 0
cdrom_1_atapi_dma = 1
cdrom_1_ide_channel = 2
cdrom_1_scsi_device_id = 2
cdrom_1_scsi_device_lun = 0
cdrom_1_iso_path =
cdrom_2_host_drive = 0
cdrom_2_enabled = 0
cdrom_2_sound_on = 1
cdrom_2_bus_type = 0
cdrom_2_ide_channel = 3
cdrom_2_atapi_dma = 1
cdrom_2_scsi_device_id = 3
cdrom_2_scsi_device_lun = 0
cdrom_2_iso_path =
cdrom_3_host_drive = 0
cdrom_3_enabled = 0
cdrom_3_sound_on = 1
cdrom_3_bus_type = 0
cdrom_3_atapi_dma = 1
cdrom_3_ide_channel = 4
cdrom_3_scsi_device_id = 4
cdrom_3_scsi_device_lun = 0
cdrom_3_iso_path =
cdrom_4_host_drive = 0
cdrom_4_enabled = 0
cdrom_4_sound_on = 1
cdrom_4_bus_type = 0
cdrom_4_atapi_dma = 1
Show last 290 lines
cdrom_4_ide_channel = 5
cdrom_4_scsi_device_id = 5
cdrom_4_scsi_device_lun = 0
cdrom_4_iso_path =
vid_resize = 0
vid_api = 1
video_fullscreen_scale = 0
video_fullscreen_first = 0
hdc_sectors = 63
hdc_heads = 16
hdc_cylinders = 4096
hdc_fn = C:\Users\Core2\Desktop\86box-c.img
hdd_sectors = 63
hdd_heads = 16
hdd_cylinders = 4092
hdd_fn = F:\data.img
hde_sectors = 0
hde_heads = 0
hde_cylinders = 0
hde_fn =
hdf_sectors = 0
hdf_heads = 0
hdf_cylinders = 0
hdf_fn =
hdg_sectors = 0
hdg_heads = 0
hdg_cylinders = 0
hdg_fn =
hdh_sectors = 0
hdh_heads = 0
hdh_cylinders = 0
hdh_fn =
hdi_sectors = 0
hdi_heads = 0
hdi_cylinders = 0
hdi_fn =
hdj_sectors = 0
hdj_heads = 0
hdj_cylinders = 0
hdj_fn =
ide_ter_enable = 0
ide_ter_irq = 10
ide_qua_enable = 0
ide_qua_irq = 11
drive_a_type = 8
drive_b_type = 0
drive_3_type = 0
drive_4_type = 0
force_43 = 0
scale = 1
enable_overscan = 0
enable_flash = 1
enable_sync = 1
opl3_type = 1
joystick_type = 0
mouse_type = msserial
enable_xtide = 1
enable_external_fpu = 1
window_w = 0
window_h = 0
window_x = 0
window_y = 0
window_remember = 0
scsicard = none
maclocal = 5558746
maclocal_pci = 10439722
fdd_01_type = 35_2hd
fdd_01_fn =
fdd_01_writeprot = 1
fdd_02_type = 35_2hd
fdd_02_fn =
fdd_02_writeprot = 0
fdd_03_type = none
fdd_03_fn =
fdd_03_writeprot = 0
fdd_04_type = none
fdd_04_fn =
fdd_04_writeprot = 0
ide_03_enable = 0
ide_03_irq = 10
ide_04_enable = 0
ide_04_irq = 11
hdd_01_sectors = 63
hdd_01_heads = 16
hdd_01_cylinders = 4096
hdd_01_bus_type = 2
hdd_01_mfm_channel = 0
hdd_01_ide_channel = 0
hdd_01_scsi_device_id = 0
hdd_01_scsi_device_lun = 0
hdd_01_fn = C:\Users\Core2\Desktop\86box-c.img
hdd_02_sectors = 0
hdd_02_heads = 0
hdd_02_cylinders = 0
hdd_02_bus_type = 0
hdd_02_mfm_channel = 0
hdd_02_ide_channel = 0
hdd_02_scsi_device_id = 0
hdd_02_scsi_device_lun = 0
hdd_02_fn =
hdd_03_sectors = 0
hdd_03_heads = 0
hdd_03_cylinders = 0
hdd_03_bus_type = 0
hdd_03_mfm_channel = 0
hdd_03_ide_channel = 0
hdd_03_scsi_device_id = 0
hdd_03_scsi_device_lun = 0
hdd_03_fn =
hdd_04_sectors = 0
hdd_04_heads = 0
hdd_04_cylinders = 0
hdd_04_bus_type = 0
hdd_04_mfm_channel = 0
hdd_04_ide_channel = 0
hdd_04_scsi_device_id = 0
hdd_04_scsi_device_lun = 0
hdd_04_fn =
hdd_05_sectors = 0
hdd_05_heads = 0
hdd_05_cylinders = 0
hdd_05_bus_type = 0
hdd_05_mfm_channel = 0
hdd_05_ide_channel = 0
hdd_05_scsi_device_id = 0
hdd_05_scsi_device_lun = 0
hdd_05_fn =
hdd_06_sectors = 0
hdd_06_heads = 0
hdd_06_cylinders = 0
hdd_06_bus_type = 0
hdd_06_mfm_channel = 0
hdd_06_ide_channel = 0
hdd_06_scsi_device_id = 0
hdd_06_scsi_device_lun = 0
hdd_06_fn =
hdd_07_sectors = 0
hdd_07_heads = 0
hdd_07_cylinders = 0
hdd_07_bus_type = 0
hdd_07_mfm_channel = 0
hdd_07_ide_channel = 0
hdd_07_scsi_device_id = 0
hdd_07_scsi_device_lun = 0
hdd_07_fn =
hdd_08_sectors = 0
hdd_08_heads = 0
hdd_08_cylinders = 0
hdd_08_bus_type = 0
hdd_08_mfm_channel = 0
hdd_08_ide_channel = 0
hdd_08_scsi_device_id = 0
hdd_08_scsi_device_lun = 0
hdd_08_fn =
hdd_09_sectors = 0
hdd_09_heads = 0
hdd_09_cylinders = 0
hdd_09_bus_type = 0
hdd_09_mfm_channel = 0
hdd_09_ide_channel = 0
hdd_09_scsi_device_id = 0
hdd_09_scsi_device_lun = 0
hdd_09_fn =
hdd_10_sectors = 0
hdd_10_heads = 0
hdd_10_cylinders = 0
hdd_10_bus_type = 0
hdd_10_mfm_channel = 0
hdd_10_ide_channel = 0
hdd_10_scsi_device_id = 0
hdd_10_scsi_device_lun = 0
hdd_10_fn =
hdd_11_sectors = 0
hdd_11_heads = 0
hdd_11_cylinders = 0
hdd_11_bus_type = 0
hdd_11_mfm_channel = 0
hdd_11_ide_channel = 0
hdd_11_scsi_device_id = 0
hdd_11_scsi_device_lun = 0
hdd_11_fn =
hdd_12_sectors = 0
hdd_12_heads = 0
hdd_12_cylinders = 0
hdd_12_bus_type = 0
hdd_12_mfm_channel = 0
hdd_12_ide_channel = 0
hdd_12_scsi_device_id = 0
hdd_12_scsi_device_lun = 0
hdd_12_fn =
hdd_13_sectors = 0
hdd_13_heads = 0
hdd_13_cylinders = 0
hdd_13_bus_type = 0
hdd_13_mfm_channel = 0
hdd_13_ide_channel = 0
hdd_13_scsi_device_id = 0
hdd_13_scsi_device_lun = 0
hdd_13_fn =
hdd_14_sectors = 0
hdd_14_heads = 0
hdd_14_cylinders = 0
hdd_14_bus_type = 0
hdd_14_mfm_channel = 0
hdd_14_ide_channel = 0
hdd_14_scsi_device_id = 0
hdd_14_scsi_device_lun = 0
hdd_14_fn =
hdd_15_sectors = 0
hdd_15_heads = 0
hdd_15_cylinders = 0
hdd_15_bus_type = 0
hdd_15_mfm_channel = 0
hdd_15_ide_channel = 0
hdd_15_scsi_device_id = 0
hdd_15_scsi_device_lun = 0
hdd_15_fn =
hdd_16_sectors = 0
hdd_16_heads = 0
hdd_16_cylinders = 0
hdd_16_bus_type = 0
hdd_16_mfm_channel = 0
hdd_16_ide_channel = 0
hdd_16_scsi_device_id = 0
hdd_16_scsi_device_lun = 0
hdd_16_fn =
cdrom_01_host_drive = 74
cdrom_01_enabled = 1
cdrom_01_sound_on = 1
cdrom_01_bus_type = 0
cdrom_01_atapi_dma = 1
cdrom_01_ide_channel = 2
cdrom_01_scsi_device_id = 2
cdrom_01_scsi_device_lun = 0
cdrom_01_image_path =
cdrom_02_host_drive = 0
cdrom_02_enabled = 0
cdrom_02_sound_on = 1
cdrom_02_bus_type = 0
cdrom_02_atapi_dma = 0
cdrom_02_ide_channel = 2
cdrom_02_scsi_device_id = 3
cdrom_02_scsi_device_lun = 0
cdrom_02_image_path =
cdrom_03_host_drive = 0
cdrom_03_enabled = 0
cdrom_03_sound_on = 1
cdrom_03_bus_type = 0
cdrom_03_atapi_dma = 0
cdrom_03_ide_channel = 2
cdrom_03_scsi_device_id = 4
cdrom_03_scsi_device_lun = 0
cdrom_03_image_path =
cdrom_04_host_drive = 0
cdrom_04_enabled = 0
cdrom_04_sound_on = 1
cdrom_04_bus_type = 0
cdrom_04_atapi_dma = 0
cdrom_04_ide_channel = 2
cdrom_04_scsi_device_id = 5
cdrom_04_scsi_device_lun = 0
cdrom_04_image_path =
serial1_enabled = 1
serial2_enabled = 1
lpt_enabled = 1
bugger_enabled = 0
[Joysticks]
joystick_0_nr = 0
joystick_1_nr = 0
[Phoenix S3 Trio64]
memory = 4
[3DFX Voodoo Graphics]
type = 0
framebuffer_memory = 4
texture_memory = 2
bilinear = 1
dacfilter = 1
render_threads = 2
recompiler = 1
[Realtek RTL8029AS]
netcard = 1
irq = 10
net_type = 0
disable_netbios = 1
But it does not work, when i ping 192.168.178.1, i only get: Request timed out
Reply 16 of 17, by Sammy
I now tryed the latest build feb2846 an Internet works..
But i get a IP adress of 10.0.2.15 and a Gateway from 10.0.2.22 ?
But in 86box config i set to PCap , but it look like i using slirp ?
Reply 17 of 17, by Sammy
I did a manual cleanup of 86box.cfg (removed the ne2000 section, was inserted when i try the ne2000 ISA card) an removed everything from ne2000 in win95.
Now i get a IP Adress from my Router and i can play Screamer Rally with other PCs over LAN.
Thank you everyone fpr helping, and thank you battler for 86box.
BTW:This is my working 86box.cfg
gameblaster = 0
gus = 0
ssi2001 = 0
voodoo = 1
buslogic = 0
netinterface = 1
netcard = ne2kpci
model = 430vx
cpu = 3
cpu_use_dynarec = 1
cpu_waitstates = 0
gfxcard = mach64x
video_speed = 5
sndcard = sb16
cpu_speed = 13
has_fpu = 1
disc_b =
disc_3 =
disc_4 =
mem_size = 98304
cdrom_1_enabled = 1
cdrom_1_iso_path =
cdrom_2_enabled = 0
cdrom_2_iso_path =
cdrom_3_enabled = 0
cdrom_3_iso_path =
cdrom_4_enabled = 0
Show last 288 lines
cdrom_4_iso_path =
vid_resize = 0
vid_api = 1
hdc_sectors = 63
hdc_heads = 16
hdd_sectors = 63
hdd_heads = 16
hde_sectors = 0
hde_heads = 0
hde_cylinders = 0
hde_fn =
hdf_sectors = 0
hdf_heads = 0
hdf_cylinders = 0
hdf_fn =
hdg_sectors = 0
hdg_heads = 0
hdg_cylinders = 0
hdg_fn =
hdh_sectors = 0
hdh_heads = 0
hdh_cylinders = 0
hdh_fn =
hdi_sectors = 0
hdi_heads = 0
hdi_cylinders = 0
hdi_fn =
hdj_sectors = 0
hdj_heads = 0
hdj_cylinders = 0
hdj_fn =
ide_ter_enable = 0
ide_ter_irq = 10
ide_qua_enable = 0
ide_qua_irq = 11
drive_a_type = 8
drive_b_type = 0
drive_3_type = 0
drive_4_type = 0
force_43 = 0
scale = 1
enable_overscan = 0
enable_flash = 1
enable_sync = 1
opl3_type = 1
joystick_type = 0
mouse_type = ps2
enable_xtide = 1
window_w = 0
window_h = 0
window_x = 0
window_y = 0
window_remember = 0
scsicard = none
maclocal = 5558746
fdd_01_fn =
fdd_01_writeprot = 0
fdd_02_fn =
fdd_03_type = none
fdd_03_fn =
fdd_04_type = none
fdd_04_fn =
ide_03_enable = 0
ide_03_irq = 10
ide_04_enable = 0
ide_04_irq = 11
hdd_01_sectors = 63
hdd_01_heads = 16
hdd_01_bus_type = 2
hdd_02_sectors = 0
hdd_02_heads = 0
hdd_02_bus_type = 0
hdd_02_fn =
hdd_03_sectors = 0
hdd_03_heads = 0
hdd_03_bus_type = 0
hdd_03_fn =
hdd_04_sectors = 0
hdd_04_heads = 0
hdd_04_bus_type = 0
hdd_04_fn =
hdd_05_sectors = 0
hdd_05_heads = 0
hdd_05_bus_type = 0
hdd_05_fn =
hdd_06_sectors = 0
hdd_06_heads = 0
hdd_06_bus_type = 0
hdd_06_fn =
hdd_07_sectors = 0
hdd_07_heads = 0
hdd_07_bus_type = 0
hdd_07_fn =
hdd_08_sectors = 0
hdd_08_heads = 0
hdd_08_bus_type = 0
hdd_08_fn =
hdd_09_sectors = 0
hdd_09_heads = 0
hdd_09_bus_type = 0
hdd_09_fn =
hdd_10_sectors = 0
hdd_10_heads = 0
hdd_10_bus_type = 0
hdd_10_fn =
hdd_11_sectors = 0
hdd_11_heads = 0
hdd_11_bus_type = 0
hdd_11_fn =
hdd_12_sectors = 0
hdd_12_heads = 0
hdd_12_bus_type = 0
hdd_12_fn =
hdd_13_sectors = 0
hdd_13_heads = 0
hdd_13_bus_type = 0
hdd_13_fn =
hdd_14_sectors = 0
hdd_14_heads = 0
hdd_14_bus_type = 0
hdd_14_fn =
hdd_15_sectors = 0
hdd_15_heads = 0
hdd_15_bus_type = 0
hdd_15_fn =
hdd_16_sectors = 0
hdd_16_heads = 0
hdd_16_bus_type = 0
hdd_16_fn =
cdrom_01_host_drive = 200
cdrom_01_image_path = F:\images\Bleifuss_Rally.cue
serial1_enabled = 1
serial2_enabled = 1
lpt_enabled = 1
bugger_enabled = 0
[Joysticks]
joystick_0_nr = 0
joystick_1_nr = 0
[Phoenix S3 Trio64]
memory = 4
type = 0
texture_memory = 2
bilinear = 1
dacfilter = 1
render_threads = 2
recompiler = 1
[Realtek RTL8029AS]
netcard = 1
irq = 10
net_type = 0
disable_netbios = 1
