First post, by MrM_21632
I'm having some issues installing Windows 3.11 on a DOS VM. Whenever I run setup.exe from the first disk, I eventually get this error:
Setup Error #214
Setup either cannot open or cannot create the
file A:\gdi.exe, which is needed to
set up Windows. Setup cannot continue.
The file may be in use by another application.
[Then it just tells me some troubleshooting tips, like quitting the app that’s using it.]
I don't know what would be using gdi.exe, since 1) it hasn't even been decompressed yet, and 2) the only things installed at the moment on the VM are DOS itself and DOSIdle. I don't think DOSIdle is the culprit, since the same error occurs when I turn DOSIdle off or uninstall it.
Anyone have any ideas as to what's going on?
