First post, by Errius
(See Game memory footprint in DOSBox)
Hi all, another question regarding emulating less than 640 KB of memory
How do I do this for a DOS booter image? You can't run LOADFIX or similar tools in that case. I want to see if a particular booter game runs in 256 KB, 128 KB or less memory.
Is this too much voodoo?
Reply 1 of 5, by Jorpho
You can always load up a random TSR repeatedly until the desired amount of conventional memory is consumed. I think you can even get away simply with running COMMAND.COM repeatedly, though I'm sure there's a more elegant tool floating around out there.
Reply 2 of 5, by VileR
But subsequently booting an image (as the OP states) would obviously render all that null and void.
Errius: just use PCem - it lets you easily configure the total amount of RAM installed. DOSBox won't work for this I'm afraid... I think there was a patch which added this functionality to the Daum build, but IIRC it didn't really work as expected.
Reply 3 of 5, by Errius
Gotcha, Pcem it is then.
Also what version of LOADFIX are you guys using? The one I have doesn't accept any switches.
I got the same result from multiple calls of an old program called LOSE64K which literally consists of just two lines:
MOV DX,FFFF
INT 27
Reply 4 of 5, by VileR
DOSBox's internal LOADFIX can be told how many KBs you want it to eat up- e.g. "loadfix -256" to allocate 256K (mind the "-", won't work without it). There's also "-f" to free it up again.
