First post, by superfury
Is the limit check offset truncated to 16 bits on the 80286 CPU? What about the 80386 and newer CPUs, during 16-bit mode(using 16-bit offsets)?
Is the memory access offset, which happens after that, truncated to 16-bits on the 80386? Or is it using the full 32/24 bits?
Note, that I'm talking about the fully input offset, aka effective address(which combined withna segment register/descriptor, translates to a linear address(and physical too on 80286 and below).
Edit: I've also just read that V86 mode(unlike Real mode) does truncate the offset before checking limits or calculating linear memory addresses?
UniPCemu Git repository
