First post, by superfury
When I try to use play.exe from the disks of the Soundblaster 2.0 with UniPCemu's new, accurate DMA emulation, it plays fine for about one second(playing the wav file from the samples directory). But after that, sound is chopped off. When I try to restart the app, emulation hangs due to the DMA never lowering the DRQ line? The setting of bit 2 of the DMAEnabled makes it wait for the next timer interval. Bit 1 halts the DMA transaction, when set. Bit 0 needs to be set(and the other bits cleared), with DREQ being 1 to be able to raise DRQ. Otherwise DRQ is lowered(low). That allows for proper timed DMA to function. DREQ works in much the same way, with bit 1 inhabiting DMA transfers until the timer times(at the tendering rate, rendering the buffered sample). DREQ bit 2 makes it lower the DREQ signal until the IRQ is acnowledged(when autoinit is triggered by the amount of samples written).
Now exit autoinit clears the autoinit flag and also sets DREQ to 0(inactive DMA, Not waiting for IRQ acnowledge&timer timeout(rendering frequency).
https://bitbucket.org/superfury/unipcemu/src/ … ter.c?at=master
Anyone can see what's going wrong? Why is executing play.exe for the second time raising DRQ permanently? The DMA isn't stopped at that point. Also, after 1 second of audio, playback becomes silent? Running play.exe a second time causes permanent BUS master being DMA, causing the CPU to 'hang'.
UniPCemu Git repository
