XT-IDE IRQ
First post, by vladstamate
What IRQ is used by xt-ide or IDE in an XT system?
On AT systems it seems to be either 14 or 15 (primary vs secondary) but what about XT? There are only 8 lines available.
YouTube channel: https://www.youtube.com/channel/UC7HbC_nq8t1S9l7qGYL0mTA
Collection: http://www.digiloguemuseum.com/index.html
Emulator: https://sites.google.com/site/capex86/
Raytracer: https://sites.google.com/site/opaqueraytracer/
Reply 2 of 7, by vladstamate
r.cade wrote:
I don't think it uses one at all. Mine has no configuration jumpers or anything for it...
So it uses polling instead of IRQ in an XT? Interesting....
Reply 3 of 7, by vladstamate
The XTIDE BIOS has a menu option for specifying an IRQ between 2 and 15 so it must be able to use it. My question is what is the default...
Reply 4 of 7, by r.cade
No DMA support = no IRQ needed.
I don't know if it's actually "polling" but it's a simple interface. The idea was that the performance of the drive far outweighed ignoring those features for simplicity, and it's still comparable in speed to the old MFM interfaces.
Reply 5 of 7, by r.cade
Must it? 😀
I think that may be for newer cards or different designs that are XT-IDE compatible... v2/v3.
But if you're talking about the original XT-IDE, I'm pretty sure it's lacking hardware support for DMA/IRQ.
Reply 6 of 7, by shspvr
If I recall right on most XT is was IRQ 2 or 5 depend the setup
8 bit bus computers (8086/8088 based XT type)
IRQ Used for
0 Ram Refresh & Clock Tick
1 Keyboard Interface
2 EGA / VGA Video (some other interface controller cards have the option of using this IRQ)
3 COM2 / COM4
4 COM1 / COM3
5 Hard Disk Controller
6 Floppy Disk
7 Parallel Printer Port LPT 1
Reply 7 of 7, by vladstamate
Just to close the loop on this. You were right, there is no IRQ required or operation in either XT-IDE or AT-IDE bioses. I managed to emulate them and for XT there is no handler and for AT the 14 and 15 IRQs are masked out during operation, so I assume the XTIDE (AT) bios just does not use them.
