Common log format
Emulation of old PCs, PC hardware, or PC peripherals.
Re: Common log format
Postby superfury » 2017-10-27 @ 16:38
Yes, it's the address that goes through Paging translation unit to RAM/hardware after all(linear->physical translation layer logging). Currently Paged accesses are usually prefixed(reads) or suffixed(writes) with the RAM layer(or none when accessing hardware, since hardware doesn't log anything, they just process and result without logging atm, due to various hardware(VGA, BIOS flash ROM) responding to it). I/O port(BUS accesses) aren't logged yet.
superfury
Postby vladstamate » 2017-10-27 @ 18:01
Questions about debug registers. You display DR0,1,2,3 then 6 followed by 5&7.
The only valid registers are 0 through 3 and then 6 and 7. Can we display them like this instead:
Code: Select all
DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000
DR6: 00000000 DR7: 00000000
In other words drop 5&.
or we could display them all (are 4 and 5 used on 486+ ?)
Code: Select all
DR4: xxxxxxxx DR5: xxxxxxxx DR6: 00000000 DR7: 00000000
User avatar
vladstamate
Postby superfury » 2017-10-27 @ 18:33
Well, that's the odd one: registers 5&7 map to the same register(DR7), or fault depending on DE in CR4. DR4 doesn't exist depending on DE bit and CPU?
http://www.felixcloutier.com/x86/MOV-2.html
https://stackoverflow.com/questions/219 ... e-not-used
superfury
Postby vladstamate » 2017-10-27 @ 18:49
Well, CR4 only "exists" in 486+.
It goes like this:
386:
CR0-CR3 - OK
CR4-CR7 - #UD
DR0-DR3 and DR6 DR7 - OK
DR 4 and 5 - #UD
486:
CR0-CR4 - OK
CR5-CR7 - #UD
DR 4 and 5 - #UD unless CR4 has DE bit disabled in which case they are DR6 and DR7
So maybe we should display 8 CR and 8 DR registers and have xxxxxxxx for anything reserved and actual value if they are used or have alias.
User avatar
vladstamate
Postby superfury » 2017-10-27 @ 20:03
It seems to be almost correct and matching UniPCemu's behaviour, looking at my ModR/M decoder: CR1 doesn't exist in any CPU(At least until Pentium)?
superfury
Postby vladstamate » 2017-10-27 @ 21:12
Ok, well in that case how about we do not display what is not present (stuff that generates #UD). I can change my code too
So for 386 display:
Code: Select all
CR0, CR2, CR3
DR0, DR1, DR2, DR3, DR6, DR7
and for 486 display:
Code: Select all
CR0, CR2, CR3, CR4
DR0, DR1, DR2, DR3, DR4, DR5, DR6, DR7
Now we need DR4 and 5 because they do have contents. I'll try to find 486 documents, it is possible back then they were separate but in recent architecture they just alias.
User avatar
vladstamate
Postby superfury » 2017-10-27 @ 22:05
Don't DR4&5 both either redirect to DR6&7 or both fault, depending on DE in CR4(Pentium+). DE set makes it fault, while cleared gives 80386-compatible redirection. Essentially always 'cleared' on pre-Pentium, so DR4&5 don't exist anyway(no way to actually access them due to #UD). So it's just CR0, CR2, CR3, DR0-3, DR6 and DR7. The other two(DR4&5) are untracable without die analysis(since it's unaccessable through instructions). Does it make sense to log an register that might not even exist, uncheckable if it does and unreachable by any instruction?
superfury
Postby vladstamate » 2017-10-27 @ 22:24
superfury wrote: Does it make sense to log an register that might not even exist, uncheckable if it does and unreachable by any instruction?
You are right. Lets drop DR4 and DR5. However CR4 does exist from 486 upwards, not from Pentium upwards.
User avatar
vladstamate
Postby superfury » 2017-10-28 @ 11:54
CR4 seems to exist on some later 80486 models(e.g. 80486-DX2) with PSE. As far as I can see, the plain 80486(SX/DX) doesn't have it? I'm emulating a plain 80486SX/DX, so no CR4 exists?
superfury
Postby vladstamate » 2017-10-28 @ 13:25
I am putting all this in writing, so that we have the specification somewhere:
https://sites.google.com/site/capex86/common
Feel free to comment if I made any mistakes.
User avatar
vladstamate
Postby superfury » 2017-10-28 @ 13:51
I've modified the logging as follows now:
CR5-7 are removed from logging, only CR4 is left on that line(only with 80486+).
DR4-5 are ommitted from logging, only DR6 and DR7 are logged(no 5&7 anymore).
I see that on your website the DR5&7 is still mentioned(which should be DR7 only now).
I still haven't had any response on the matter of memory transactions? Any idea about it? I've already given two transaction methods I've implemented in UniPCemu(the latter one is currently active in my current commits), any input on how to log those?
superfury
Postby vladstamate » 2017-10-28 @ 14:07
superfury wrote:I've modified the logging as follows now:
Perfect!
superfury wrote:I see that on your website the DR5&7 is still mentioned(which should be DR7 only now).
Nice spotted. I fixed it now.
superfury wrote:I still haven't had any response on the matter of memory transactions? Any idea about it? I've already given two transaction methods I've implemented in UniPCemu(the latter one is currently active in my current commits), any input on how to log those?
Yes, give me some time to think of it. I've been busy implementing the register log and fix some 386 issues. I know it is important we figure this out as I've already reserved space on the webpage/doc for it, as you saw.
User avatar
vladstamate
Postby vladstamate » 2017-10-28 @ 14:12
BTW I put the spec on the OP, so it is easier to see.
User avatar
vladstamate
Postby superfury » 2017-10-28 @ 16:35
You still forgot to update one thing: the DR5&7 on the full log example, which is supposed to be DR7.
Edit: We also still need to do something about the memory access logging, as it's essential to things like instructions that have memory operands(their input and output has effect on execution after all, in the same way the registers do(although it may be at different times, as registers are more frequently used due to speed)).
Any ideas about logging those? I think the latter format is better, as it's more compact(due to shorter notation and single lines for each memory access) while still logging every data required.
superfury
Postby superfury » 2017-11-23 @ 12:58
One little thing to note: the memory accesses are logged as a tab after the executing cycle: this can be either between instructions(in the common log format) as well as after the instruction line itself(following the instruction disassembly(e.g. "call 00009190<tab>memoryaccess")).
For example(from the BIOS log failing to boot a floppy disk):
Code: Select all
f000:0000909e E8 EF 00 call 00009190   Physical(r):000F9190=33(3); Paged(r):000F9190=33(3); Physical(r):000F9191=DB(Û); Paged(r):000F9191=DB(Û); Physical(r):000F9192=8A(Š); Paged(r):000F9192=8A(Š); Physical(r):000F9193=5E(^); Paged(r):000F9193=5E(^)
superfury
Postby vladstamate » 2017-11-27 @ 18:04
superfury wrote:
Code: Select all
Questions:
1) Does (r) mean a byte read?
2) What do you print for non-ASCII characters? Like those with code < 32 ?
3) (not important to the format but just curious): who issues those reads? The call instruction? CALL should issue writes to the stack, where are they?
User avatar
vladstamate
Postby superfury » 2017-11-27 @ 19:51
vladstamate wrote:
superfury wrote:
Code: Select all
Questions:
1) Does (r) mean a byte read? Yes. Otherwise it logs (w) for writes.
2) What do you print for non-ASCII characters? Like those with code < 32 ? NULL, 0xD and 0xA are patched to space to prevent invalid logging. All others are logged as-is(%c).
3) (not important to the format but just curious): who issues those reads? The call instruction? CALL should issue writes to the stack, where are they? All logged reads/writes are by the CPU. So it's the executing instruction as well as Paging table lookups, descriptor fetches/writeback(e.g. busy task bit) and prefetching unit fetches. The previous reads/writes are on the previous lines. The access after the instruction is the final memory access by the instruction on that cycle. Although, usually this isn't with the instruction, as the BIU finishes the access BEFORE the instruction is finished(executed stays 1, prompting the debugger to start logging initial register state etc. that very cycle. So it usually only happens on that cycle when it's an access that's not emulated through the BIU(like a memory access without using the BIU, like loading/storing descriptors and Paging-related tables atm.)
In this case it's probably a prefetching PIQ dword being fetched.
superfury
Postby superfury » 2018-4-25 @ 05:31
I've been thinking, isn't prefetch a special kind of read(it reads into the prefetch instead of normal transactions, which read for the application to process, instead of opcodes)? Shall I modify the (r) to become (p) for those fetches? That way, you can easily see the normal transactions from the prefetch ones?
superfury
Postby vladstamate » 2018-4-25 @ 18:45
Prefetch is asynchronous with the instruction execution though. I would not log them into anything related to an instruction.
User avatar
vladstamate
Postby superfury » 2018-4-25 @ 20:40
But they are related to the instruction? It's the logging of BIU fetches after all in both the (r) and (p) cases, just into a different buffer(either buffered for the EU to read as data(e.g. data from a memory operand, like in mov ax,[1324]) or the opcode bytes(which are added to the prefetch buffer instead)). Both are BIU reads that are transferred at cycle T3-T4. The only difference is the destination?
superfury
PreviousNext
Return to PC Emulation
Who is online
Users browsing this forum: collector, loblolly986 and 2 guests
