Intel dropping UEFI CSM (legacy BIOS support) for new systems in 2020
Emulation of old PCs, PC hardware, or PC peripherals.
Postby eton975 » 2017-11-18 @ 20:12
Link
Intel's dropping support for the UEFI Compatibility Support Module (also known as 'level 2 compatibility') for their new platforms come 2020. Come then, you'll be unable to natively boot from devices with a MBR partition table, which was the primary method to boot the system from BIOS. Curious (!) to see how this will affect things like older graphics cards and PCI/PCIe NICs that only (AFAIK?) have VGA BIOS support, and hook in to the system boot through interrupt capture.
Personally, I feel this isn't even trying to fix something that ain't broke, but rather, breaking what was already fixed with UEFI for little good reason. However, perhaps I'm underestimating the effort it takes to validate BIOS compatibility and peripheral emulation on new hardware...
eton975
Re: Intel dropping UEFI CSM (legacy BIOS support) for new systems in 2020
Postby Kubik » 2017-11-18 @ 21:48
The fact Intel is dropping support doesn't mean that there will be no CSM support in BIOS. It's responsibility of the BIOS vendor (IBV) to provide CSM module, and board manufacturer can decide if they want it or not. The problem would be onboard graphics from Intel that won't get VGA BIOS, thus you'll need to use discrete VGA card. Other problem might be certain level of USB support in DOS, if Intel decides to remove the legacy emulation stuff.
Kubik
Postby cyclone3d » 2017-11-18 @ 22:04
I don't see this as a problem at all for new hardware as of 2020.
All new video cards already support UEFI and have for a couple years.
Unless you are wanting to run really old cards on a newer motherboard I don't see why this would be a problem at all.
Maybe it will force some companies to actually update their hardware/software that was never updated to work on newer stuff. Having to try to get 20+ year old software/hardware to work on newer systems because a company will not spend a few grand for a newer version is infuriating.
And then when they have to use an old OS that is not allowed on the network for security reasons they complain about it.
User avatar
cyclone3d
Postby Zup » 2017-11-19 @ 08:17
I'm worried about alternate OSs and legacy hardware.
- DOS is still useful for some things, like HDD tests and BIOS flashing on some devices.
- There are some bootable tools (are Memtest and Memtest + still developed?) that doesn't fully support UEFI, or does not support it at all.
- Some flavours of Linux don't fully support UEFI. I'm thinking about secure booting and (although the link does not say anything about it) maybe they'll force it.
- Hiren's Boot CD (not updated since a long time, but still useful) and Ultimate Boot CD... well, they won't boot.
- What about older/legacy cards with BIOS? Think about a business that (for some reason) needs to connect an old (SCSI of FC) disk array to a newer computer. Those systems use HBAs with their own BIOS... will they work in a non-legacy UEFI environment?
I'm selling some stuff!
User avatar
Zup
Postby eL_PuSHeR » 2017-11-19 @ 08:38
I am worried too because I don't like UEFI, no matter how marketing tries to sell it to us.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
User avatar
eL_PuSHeR
Moderator
Postby Jo22 » 2017-11-19 @ 10:55
Oh my, 2020, that's in about two years already. :( In worst case, I hope there will be BIOS emulators, at least.
Just like Boot Camp for booting Windows XP on an EFI-based Intel Mac or something similar to those
BIOS emulators/compatibility layers the Hackintosh scene used to use in the past years.
Jo22
Postby Kubik » 2017-11-19 @ 11:18
Zup wrote:I'm worried about alternate OSs and legacy hardware.
- Flash tools for EFI shell / Windows / Linux exist for many, many years already. Most HDD tests I've seen are Windows only.
- Memtest86 supports UEFI boot
- Secure Boot requires CSM to be disabled. I bet all major Linux distributions support UEFI boot.
- Hiren's Boot CD - yes, it's not updated since a long time. Maybe using tools from this century would help? :)
- Connecting an old disc array to a newer computer isn't an issue. Booting from it would, but from my experience, those devices are used mostly as data storage. I am more like guessing that the problem will basically be newer system won't support corresponding bus (ISA, PCI, PCI-X etc.)
Kubik
Postby Azarien » 2017-11-20 @ 14:26
cyclone3d wrote:All new video cards already support UEFI and have for a couple years.
How new and how old cards are we talking about? Is it safe to assume all PCIe cards support UEFI?
Would it affect secondary cards (not used during boot) as well?
Azarien
Postby eton975 » 2017-11-20 @ 21:30
No, it's definitely not safe. However, I believe most stuff since the GTX 600 series and AMD 7000 series -> 200 series support UEFI.
As for the other cards, potentially yes. A modern OS should(?) still be able to detect them with its drivers as long as they don't rely on asking the BIOS about what devices are present.
eton975
Postby Kubik » 2017-11-21 @ 09:14
eton975 wrote:A modern OS should(?) still be able to detect them with its drivers if they don't rely on asking the BIOS about what devices are present.
Detecting and configuring a device is a feature of PCI / PCI-X / PCIe since the very beginning.
Kubik
Postby Jade Falcon » 2017-11-22 @ 18:43
eL_PuSHeR wrote:I am worried too because I don't like UEFI, no matter how marketing tries to sell it to us.
UEFI is ok with legacy bios support. But the damn crappy UI's they put on alot of boards makes me pull out my hair.
Jade Falcon
BANNED
Postby eton975 » 2017-11-23 @ 02:16
For PCI, AFAIK not necessarily. Plenty of PCI cards I know use Option ROMs that use interrupts 18h and 19h (25th and 26th interrupts, counting 0) and don't work properly otherwise.
Not sure about PCI-X and PCIe cards though.
eton975
Postby Jo22 » 2017-11-23 @ 23:32
In the future, could good old SeaBIOS be used as an alternative CSM, perhaps ?
The Wikipedia article of SeaBIOS mentions "SeaBIOS as a Compatibility Support Module (CSM) for
Unified Extensible Firmware Interface (UEFI) and Open Virtual Machine Firmware (OVMF)
Unfortunately, I don't know what to make of that. But if UEFI uses an standardized API/ABI,
couldn't a generic version of SeaBIOS run atop of UEFI and provide some degree of backwards compatibility ?
Please forgive my ignorance, but I know very little about UEFI's internals.
Maybe I get it wrong and the current CSM is implemented as a payload that works on its own.
Edit: Seems removal of CSM may only be the beginning. Other core components from the PC/XT/AT eras *could* be next.
I just hope that x87 and the classic 8086 registers will stay for a while, so VMs can use them in hardware-assisted virtualization, at least.
Also, I hope that AMD, VIA or mainboard makers in general, won't follow intel's approach so quickly,
now that FreeDOS and OS/2 (ArcaOS) are making some progress..
Jo22
Postby Jo22 » 2017-12-22 @ 08:30
Just found something interesting. Over ten years ago, researchers from IBM were working on a BIOS emulator for EFI-based systems.
http://www.insanelymac.com/forum/topic/11953-bambios-bios-emulator-for-efi/
Jo22
Postby Kubik » 2017-12-24 @ 13:52
PCI and PCI-X are the same from software point of view. PCIe is backward compatible, but the configuration space is extended to 4KB, where first 256 bytes are accesible via the same mechanism as PCI / PCI-X, and whole 4KB are accessible only via memory mapped I/O.
Basic card configuration is typically done by BIOS. BIOS allocates resources for the card (I/O, memory mapped, IRQ). Option ROM can configure additional features, detect attached drives, install legacy handlers (interrupt 13h, 18h, 19h etc), eventually provide some sort of setup program etc.
Anyway, the point is that mechanism of detecting and configuring the card is part of PCI specification.
Kubik
Return to PC Emulation
Who is online
Users browsing this forum: No registered users and 2 guests
