PCem Need for Speed 2 SE 3DFX Problem
Emulation of old PCs, PC hardware, or PC peripherals.
Postby Sandi1987 » 2017-12-02 @ 11:14
It's say i need glide2x.dll. I copy dll but still doesn't work. I have Windows 98 SE.
Sandi1987
Re: PCem Need for Speed 2 SE 3DFX Problem
Postby vladstamate » 2017-12-02 @ 15:49
You might get a lot more answers in the PCEm forums.
However, that being said, where did you copy the glide2x.dll? It should be either in the same location as the game executable (.exe) or in System32 folder in Win98. Also, what is the actual error?
User avatar
vladstamate
Postby Zup » 2017-12-02 @ 16:22
Did you install the 3dfx drivers?
I'm selling some stuff!
User avatar
Zup
Postby leileilol » 2017-12-02 @ 23:36
I've had no issue running NFS2SE on 3dfx in PCem, so i'm sure this is yet another pebkac.
Voodoo2s aren't 100mhz stock
Geforce256 isn't released as a beta on New Years '99 under the Quadro brand
386DX vs SX isn't about a missing FPU
DOS gaming isn't a bilinear 320x200 16:10
DOS PCs aren't better than the Macintosh
Old PCs aren't 'aesthetic'
User avatar
leileilol
Postby Sandi1987 » 2017-12-03 @ 06:56
I install Diamond Monster 3D Driver and it's working. Why i can't accelerate in Need for Speed 1: SE in MS-DOS in PCem? First version works normally.
EDIT:
I have this problem in RIP version. Windows version NFS 1 SE works fine in Windows 98.
Sandi1987
Return to PC Emulation
Who is online
