First post, by Dacaskos
From time to time I search, in vain, for something other than Daemon 3.47 (the last version afaik that supports cdda and which doesn't work under modern OSes) that support CDDA/Red Book Audio cd image mounting.
Wincdemu doesn't. Virtual Clone Drive either.
Are there any solutions out there?
Reply 1 of 10, by Stretch
Try MagicDisc
Win10 - AMD Ryzen 9 3900 - 16 GB - GeForce RTX 2060S - Sound BlasterX AE5-Plus
Win98SE - ASRock 775i65G R3.0 - Celeron 2.2 GHz - 2 GB - GeForce FX5700 - Audigy 2 ZS
Win98SE - Via Apollo Pro Mobo - Pentium II 233 - 256 MB - Voodoo 3 1000 - Yamaha YMF724
Reply 3 of 10, by Dacaskos
Firtasik wrote:
Alcohol 52% Free Edition
Stretch wrote:
Try MagicDisc
Thanks! But I should've mentioned "without adware"
Are those soft free from stuff? Afaik alcohol demands you to install lots of adware crap to make it work.
In any case, thanks again.
Reply 7 of 10, by Dacaskos
konc wrote:
If I may ask, what do you mean that Daemon 3.47 is the last version which supports mounting of data+audio mixed cds? What's wrong with current version?
As I said, "afaik" at least for sometime Daemon dropped support to audio tracks (something like in the 00's, more than ten years now). I don't know if they support it again in newer versions but I'm not willing to try the newer releases for they have a ton of adware stuff attached to it.
leileilol wrote:
I use Virtual CloneDrive with my CCDs and the CD audio works in 7 x64.
Hmmm... I didn't know V. CloneDrive did that. The only problem with Virtual Clonedrive is it won't support bin/cue files.
Magiciso doesn't install on Win10 x64 for some reason, but if I remember correctly it also had troubles with CDDA audio.
It's amazing how virtual cd drive mounting software is plagued with adware, some of them even without your permission (the days of "Do you want to install CRAP BAR with it?" tick boxes are long gone now. They often install shit without your permission as well)
Anyway, thanks for all the help so far 😀
Reply 8 of 10, by ZellSF
Don't know about Alcohol 52%, but the only ads in Daemon Tools Lite is in its own GUI, which I haven't seen since I installed the program (I double click images to mount them). There's a million much worse ways advertisers are getting to you whenever you browse the web. And no, you haven't blocked all of them, even if you think you have.
Daemon Tools supports audio tracks just fine and always has, what it dropped support for after 3.47 was pretending it was a CD drive with analog audio output as opposed to digital audio output. I don't think that distinction even exists in Windows 10.
Virtual CloneDrive works fine for bin/cue files with CD audio. Why wouldn't it? Only problem with Virtual CloneDrive is that you can forget about playing games with advanced copy protections.
Reply 9 of 10, by leileilol
It works best with CCD files. My CCD'd safedisc games work fine with it.
Reply 10 of 10, by konc
I'd suggest trying the current version of daemon tools, as you are making a lot of wrong assumptions about something you haven't even seen. Plus you can always buy a 3 pcs lifetime license for the lite version which gets rid of the ads for something like 5 euros.
