First post, by IMeganElisabeth
Once designating a select amount of RAM to Virtual Box once closed all of that RAM will be reallocated to my host OS, right? Where do I go to confirm all RAM is properly available for use again on my main OS upon closing Virtual Box?
Reply 1 of 13, by BloodyCactus
its.. automatic. its not like you run virtualbox and its a black hole that just eats memory. when you close an app the os relcaims the app memory.
--/\-[ Stu : Bloody Cactus :: http://kråketær.com :: http://mega-tokyo.com ]-/\--
Reply 2 of 13, by IMeganElisabeth
I've heard of sometimes having to manually designate it back with a Mac because it didn't automatically like it was suppose to.. so maybe this is just a Mac issue.
Reply 5 of 13, by gdjacobs
OS X should reclaim RAM as the associated processes are killed and reaped. Not doing so would constitute a fundamental bug in the operating system.
Reply 6 of 13, by IMeganElisabeth
Thank you. In order to check if it is would I go to usage or something?
Reply 8 of 13, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
It's automatic and there is no way to check as the process using the RAM is no longer running. Modern OS do not have problems with this. Don't worry until you actually run into problems.
If you really worry, ask in the forums of VirtalBox.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 10 of 13, by IMeganElisabeth
Ah gotcha thanks so much.
Reply 12 of 13, by gdjacobs
If the VBox process is still around, there will still be memory allocated to it. You'll be able to see that in your choice of process viewer. It's the job of the memory management subsystem to reclaim memory from the process as it's relinquished which includes the process being killed and torn down. This is a highly stable and reliable function in modern operating systems. As you can imagine, a kernel memory leak would be very bad news, so it has to be properly written and heavily tested.
Reply 13 of 13, by IMeganElisabeth
Thank you so very very much for explaining this in depth to me.
