PCem Backup
First post, by IMeganElisabeth
Is there a way to backup the current state of a machine in PCem like you can with a VM in VirtualBox?
Reply 2 of 4, by IMeganElisabeth
leileilol wrote:
You could probably zip up the hard drive images, the nvr file and the cfg file. There's no state saving or undo disks or anything like that.
Okay, I know where the hard drive image is so if I just find an application to zip it will it stop continuing to change along if I make a copy or is still going to continue to change once zipped? I’m trying to create a safe backup in case I break it to not have to a fresh install
Reply 3 of 4, by dragon57
The zipped copy is totally separate than the hard drive image PCEM uses, so any time you use that image w/PCEM and make changes, you should zip up the image again when you shutdown PCEM. You can either overwrite the original zip file if you only want one backup, or you could have as many backups as you want, depending on what use you put the images to. I, for one, have more than one backup of the initial image I created. One is for certain games, another is a mix of different types of games, and lastly one for applications. There are many possibilities.
Reply 4 of 4, by IMeganElisabeth
Thank you very very much for this information!
