Winevdm
Reply 80 of 98, by collector
Just tried some Win16 SCI games. They are mostly working, but KQ6 Win does not properly display the cursor, but otherwise seems to run OK. Shivers runs, but MMG Deluxe errors out.
The Sierra Help Pages -- New Sierra Game Installers -- Sierra Game Patches -- New Non-Sierra Game Installers
Reply 83 of 98, by filipetolhuizen
Right now, only Battle Chess runs without sound due to the VM being run in Enhanced mode (this message is shown on start and when trying to enable sounds) and Darkseed II crashes upon start, just like in wowexec on 32-bits Windows.
Reply 84 of 98, by crazyc
filipetolhuizen wrote on 2020-05-18, 02:06:
This requires highly accurate 8254 emulation, this probably won't be fixed anytime soon if at all.
For me it crashes if run from the cd but a minimum install and run from the hdd it works. I put a PR, https://github.com/otya128/winevdm/pull/684, to fix the opening credits movie. The other movies require indeo 5 to be enabled, https://github.com/juanitogan/rbxit/wiki/Inde … o-codec-install
Reply 85 of 98, by filipetolhuizen
crazyc wrote on 2020-05-18, 02:46:
This requires highly accurate 8254 emulation, this probably won't be fixed anytime soon if at all. […]
If I run from the CD, it just plays a MIDI with a hand cursor and a black screen (I can also hear a critical warning sound from Windows itself). Minimum install still crashes for me even after enabling Indeo 5.0
Reply 89 of 98, by filipetolhuizen
crazyc wrote on 2020-05-19, 13:46:
There's not enough information there to understand what's happening. If you can get a trace, that would be better.
This is the register I got from x32dbg (I tried to run otvdmw again a few times after it crashed).
    register(1).txt
    30.09 KiB
    22 downloads
Reply 91 of 98, by filipetolhuizen
crazyc wrote on 2020-05-20, 01:42:
Definitely need a WINEDEBUG=+relay,+int21 trace too.
trace.txt attached.
    trace.txt
    20.34 KiB
    19 downloads
Reply 92 of 98, by crazyc
I think the cd files need to be in the root directory. Use subst, a full install or something.
Yours:
2594:Call KERNEL.128: GETPRIVATEPROFILESTRING(12ef12ef "DIRECTORY",12ef12ec "CD",12ef12e9 ".\\",12ef:c80e,0080,12ef13dc ".\\DARKSEED.INI") ret=1237:00c0 ds=12ef
1228:2594:trace:file:GetPrivateProfileString16 1407: .\DARKSEED.INI DIRECTORY CD
1228:2594:trace:file:GetPrivateProfileString16 1466: ("DIRECTORY", "CD", ".\\", 02CDA4AE, 128, ".\\DARKSEED.INI")
2594:Ret KERNEL.128: GETPRIVATEPROFILESTRING() retval=00000027 ret=1237:00c0 ds=12ef
2594:Call KERNEL.88: LSTRCPY(12e73c88,12efc80e "E:\\BITTOR~1\\DARK-S~1\\DARKSE~1\\DARKSEED\\") ret=122f:07aa ds=12ef
2594:Ret KERNEL.88: LSTRCPY() retval=12e73c88 ret=122f:07aa ds=12ef
2594:Call KERNEL.88: LSTRCPY(12e7273e,12e73c88 "E:\\BITTOR~1\\DARK-S~1\\DARKSE~1\\DARKSEED\\") ret=122f:07bb ds=12ef
2594:Ret KERNEL.88: LSTRCPY() retval=12e7273e ret=122f:07bb ds=12ef
2594:Call KERNEL.88: LSTRCPY(12e73c68,12ef12f9 "sndtrack\\") ret=122f:07ca ds=12ef
2594:Ret KERNEL.88: LSTRCPY() retval=12e73c68 ret=122f:07ca ds=12ef
2594:Call KERNEL.88: LSTRCPY(12e73ca8,12e73c88 "E:\\BITTOR~1\\DARK-S~1\\DARKSE~1\\DARKSEED\\") ret=122f:07db ds=12ef
2594:Ret KERNEL.88: LSTRCPY() retval=00000000 ret=3a45:4144 ds=425c --!stack trashed!
RETF (0266460d): Return segment RPL is less than CPL.
Mine:
271c:Call KERNEL.128: GETPRIVATEPROFILESTRING(12ef12ef "DIRECTORY",12ef12ec "CD",12ef12e9 ".\\",12ef:c80e,0080,12ef13dc ".\\DARKSEED.INI") ret=1237:00c0 ds=12ef
271c:Ret KERNEL.128: GETPRIVATEPROFILESTRING() retval=0000000c ret=1237:00c0 ds=12ef
271c:Call KERNEL.88: LSTRCPY(12e73c88,12efc80e "G:\\DARKSEED\\") ret=122f:07aa ds=12ef
271c:Ret KERNEL.88: LSTRCPY() retval=12e73c88 ret=122f:07aa ds=12ef
271c:Call KERNEL.88: LSTRCPY(12e7273e,12e73c88 "G:\\DARKSEED\\") ret=122f:07bb ds=12ef
271c:Ret KERNEL.88: LSTRCPY() retval=12e7273e ret=122f:07bb ds=12ef
271c:Call KERNEL.88: LSTRCPY(12e73c68,12ef12f9 "sndtrack\\") ret=122f:07ca ds=12ef
271c:Ret KERNEL.88: LSTRCPY() retval=12e73c68 ret=122f:07ca ds=12ef
271c:Call KERNEL.88: LSTRCPY(12e73ca8,12e73c88 "G:\\DARKSEED\\") ret=122f:07db ds=12ef
271c:Ret KERNEL.88: LSTRCPY() retval=12e73ca8 ret=122f:07db ds=12ef
271c:Call KERNEL.85: _LOPEN(12ef13cd "gfile.hdr",0020) ret=122f:0a14 ds=12ef
The long path is overwriting the stack.
Reply 93 of 98, by filipetolhuizen
Makes total sense conidering it's a 16-bit game. I'll try that.
EDIT: I shortened the path and did a full install, now it got stuck on the black screen with a hand cursor playing a MIDI and I could hear the Windows critical stop sound right before that. Made a trace.txt from this run.
    trace.txt
    2.2 MiB
    20 downloads
Reply 95 of 98, by filipetolhuizen
crazyc wrote on 2020-05-23, 22:00:
This is the same crash as if it's run from the cdrom. Turns out it's intentionally dereferencing a null pointer. Try https://ci.appveyor.com/project/otya128/winev … 705sc/artifacts .
Thanks! It's working 100% now. Mike Dawson's animation is a bit jerky, but I guess this is a side effect of the game running on a faster system than it was meant to be played, not from winevdm.
Reply 96 of 98, by xpclient
Just joined this forum because of all the exciting topics here about PC emulation: PCem, BoxedWine, The Wrapper Collection Project but best of all Winevdm! This project has come a long way since 2018 in just 2 years and it runs quite a lot of Win16 apps beautifully!
I am eternally grateful to the hundreds of people involved in the original Wine for so many decades and to Otya for Winevdm and crazyc who has fixed tons of my favorite Microsoft Home range of16-bit/hybrid apps for me as I reported various issues in the last few days. Thanks to Edward Mendelson too for the installer and his info page which is how I found about wineVDM/OTVDM and NTVDM x64.
Rather than 16-bit apps and games which were later ported to 32-bit and work today on modern versions of Windows, I am more excited by the huge number of (now hard to discover or obtain) 16-bit only apps and games which never made it to 32-bit. Some of them e.g. Entertainment Pack, Microsoft Home range of titles are very rare, which this gem of a project brought to life!
I am so happy to find this forum too as I am still discovering many 16-bit apps and games in this discussion which I never played or knew but can now play! My Windows journey started with late Windows 3.1/early Windows 95 era.
In the last few days I tested the following apps and games with WineVDM and they all work now. Some had breaking issues which crazyc fixed! All of these are Microsoft-made or Microsoft-published apps:
P.S. Please note that I am unable to send or reply to any PMs until my post count increases with more participation.
Reply 97 of 98, by crazyc
People at microsoft are possibly using it (or are at least aware of it's existence) https://techcommunity.microsoft.com/t5/window … it/ba-p/1671418 . There's no mention of the ntvdm64 registry key, MS doesn't want to talk about that for support reason I'm sure. The Computer History Museum has users too, https://computerhistory.org/blog/political-gu … ng-a-president/ .
From the CHM blog
There are some issues with the video playback, where half of the video will show and you can hear the audio,
This appears to be caused by the videos being converted to 24 bit color by win16 Quicktime itself and since the bitmap is larger than 64K, the max size of a win16 segment, it stops so it doesn't overflow. Other quicktime programs I've tried work in 256 color compat mode where quicktime does 8bit conversion and windows itself then converts it to 24bit color.
Reply 98 of 98, by xpclient
crazyc wrote on 2020-09-25, 00:14:
OTVDM being acknowledged on an article on Microsoft.com gave me the chance to mention it on Wikipedia in the Windows 3.1 article. Although some idiot there on Wikipedia is causing problems saying it is not relevant. 🙄🙄🙄
