First post, by superfury
superfury
Offline
There's the choice of 16-bit and 32-bit pushes on both stacks(if stack switching), there's the operand size of the call instruction itself. Is said operand size used for all parameters? Thus also differentating between esp/sp and eip/ip as well? Also affecting always stack alignment?
UniPCemu Git repository
