First post, by superfury
Apparently, you can JMP to a call gate, but it doesn't save any return information? It's safe to do with task switches(which can't iret to the previous task because it's a JMP, but when using JMP to call a function, why would you want to do that? Unless you have far return data on the stack already?
UniPCemu Git repository
Reply 1 of 4, by peterferrie
Yes, if you have pushed the return address, perhaps as a tail-call optimisation (i.e. call to a function which links to a leaf function), then you can jump through the gate to save the size of the return instruction.
Reply 2 of 4, by superfury
And if you simply execute a JMP instead of a required CALL from a main(empty stack) routine? That will go wrong on RETF?
Also, JMP doesn't change CPL, while CALL does?
Reply 4 of 4, by superfury
Just improved privilege levels for MAX(CPL,RPL)<=DPL requirement to apply to non-code segments as well(as wrll as removing the JMP specific check(might need reimplementing it on call gates). Might even remove that specific part altogether because it's already handled further upwards.
