First post, by Battler
What exactly does the Logitech C7 serial mouse do on the power-up sequence? I mean, the sequence appears to be, set DTR active, then set RTS active, then wait for something, but for what? 86Box's emulated mouse right starts a timer when that happens, that sends the 0x4D ('M') but Windows 2000 (and it seems Windows NT 3.51 as well) doesn't seem to like that, it seems to be expecting something to happen in the modem status register of the serial port. What does the real mouse do when it's powered up?
Reply 1 of 2, by Jo22
It's not much, but a bit of what you mentioned is described on page 12 of the Logimouse C7 technical reference manual.
Reply 2 of 2, by Battler
I just got reports back from a person who tested the real mouse for me, and basically, when you set DTR active, the mouse raises DSR (and you get a MSR interrupt from the serial port if the serial port is appropriately configured), and when you set RTS active, the mouse raises CTS (and you get a MSR interrupt again).
