First post, by superfury
The documentation states(80386 programmer's reference manual: https://pdos.csail.mit.edu/6.828/2008/readings/i386/SHRD.htm):
IF ShiftAmt >= OperandSize
THEN (* Bad parameters *)
r/m := UNDEFINED;
CF, OF, SF, ZF, AF, PF := UNDEFINED;
So, with 16-bit operands, this will happen(32-bit operands are unchanged due to the mask of 1F, no overflow can happen):
Does that mean that shifts of 16(cnt=0x10) and up are NOPs? Or shifts of 17(0x11) and up are NOPs? I'd assume OperandSize==16 in this case?
UniPCemu Git repository
UniPCemu for Android, Windows and PSP on itch.io
Older UniPCemu PC/Android/PSP releases
Reply 1 of 15, by BloodyCactus
did you test it? its super easy to test.. but of course not, you never do real tests you just ask us.
the answer might surprise you. I'll give you a clue, its not a No-Op...
--/\-[ Stu : Bloody Cactus :: http://kråketær.com :: http://mega-tokyo.com ]-/\--
Reply 2 of 15, by superfury
Well the most difficult part is that I don't have any real 80386/80486 to test that on, so that's kind of impossible.
All I have is documentation and emulator(fake86, Bochs, Dosbox, qemu, PCem etc.) and these forums as a reference.
Dosbox doesn't seem to do anything special, as far as I can see.
Bochs says in it's Pentium-based documentation, it's apparently reloading the second parameter to it's original value and repeat shifting normally(thus shifting param1::param2::param2 effectively). Or it's some kind of bit index being used, taking said bit(a counter counting down) on said value each shift to shift into the first parameter. And said counter wraps around 16-bits?
PCem doesn't add much...
Edit: Pcem says the top n bits(when past 16 shifts gets added zeroes?
Reply 4 of 15, by superfury
So past 16 bits shifted in it starts to shift in zeroes at the LSb(shld) or MSb(shrd), due to emptied src?
Reply 5 of 15, by BloodyCactus
On real hardware;
mov eax,0x12345678
mov ebx,0x87654321
shld eax,ebx,4
eax=0x23456788
ebx=0x87654321
mov eax,0x12345678
mov ebx,0x87654321
shld eax,ebx,0x96
eax=0x9E21D950
ebx=0x87654321
mov eax,1
shl eax,0x33
eax=0x00080000
mov eax,1
shl eax,0x20
eax=0x00000001
mov eax,1
shl eax,0x21
eax=0x00000002
mov eax,-1
shl eax,0x24
eax=0xFFFFFFF0
As you can see, the shift bit counts acts as MOD. Dosbox also gives same matching results.
Reply 6 of 15, by superfury
Well, I know the cnt (third parameter, either CL or immediate byte) is taken modulo 32(as is documented). But then, while shifting past count 16, what happens? Does it merrily start shifting zeroes from the now-emptied second operand(what UniPCemu does)?
Current implementation of SHLD/SHRD 16-bit:
extern byte BST_cnt; //How many of bit scan/test (forward) times are taken?
//0F AA is RSM FLAGS on 386++
//SHL/RD instructions.
word tempSHLRDW;
void CPU80386_SHLD_16(word *dest, word src, byte cnt)
byte shift;
cnt &= 0x1F;
BST_cnt = 0; //Count!
if (cnt && (cnt<16)) //To actually shift?
if (!dest) { if (CPU8086_internal_stepreadmodrmw(0,&tempSHLRDW,MODRM_src0)) return; } //Read source if needed!
else if (CPU[activeCPU].internalinstructionstep==0) tempSHLRDW = *dest;
if (CPU[activeCPU].internalinstructionstep==0) //Exection step?
BST_cnt = cnt; //Count!
for (shift = 1; shift <= cnt; shift++)
if (tempSHLRDW & 0x8000) FLAGW_CF(1); else FLAGW_CF(0);
tempSHLRDW = ((tempSHLRDW << 1) & 0xFFFF)|((src>>15)&1);
src <<= 1; //Next bit to shift in!
if (cnt==1) { if (FLAG_CF == (tempSHLRDW >> 15)) FLAGW_OF(0); else FLAGW_OF(1); }
flag_szp16(tempSHLRDW);
++CPU[activeCPU].internalinstructionstep;
CPU_apply286cycles(); /* Apply cycles */
if (dest==NULL)
CPU[activeCPU].executed = 0; //Still running!
return;
if (dest)
*dest = tempSHLRDW;
else
if (CPU8086_internal_stepwritemodrmw(2,tempSHLRDW,MODRM_src0,0)) return;
void CPU80386_SHRD_16(word *dest, word src, byte cnt)
byte shift;
cnt &= 0x1F;
if (cnt == 1) FLAGW_OF(((tempSHLRDW & 0x8000) ^ ((src & 1) << 15)) ? 1 : 0);
Show last 25 lines
FLAGW_CF(tempSHLRDW & 1);
tempSHLRDW = ((tempSHLRDW >> 1)|((src&1)<<15));
src >>= 1; //Next bit to shift in!
if (dest==NULL)
return;
if (dest)
*dest = tempSHLRDW;
else
Reply 7 of 15, by BloodyCactus
I did a anothter quick shl + shld test
mov ax,1
shl ax,0x11
ax=0x00
mov ax,1
shl ax,0x21
ax=0x02
mov ax,1
mov bx,0xffff
shld ax,bx,0x21
ax = 3
bx = 0xffff
mov ax,1
mov bx,0xffff
shld ax,bx,0x20
ax = 1
bx = 0xffff
mov ax,1
mov bx,0xffff
shld ax,bx,0x11
ax = 0xffff
bx = 0xffff
Reply 8 of 15, by superfury
The issue is with that final one(all others are acting as documented due to masking the count with 1Fh):
mov ax,1
mov bx,0xffff
shld ax,bx,0x11
ax = 0xffff
bx = 0xffff
How did it arrive at FFFF in AX? Shifting with 10h will result in AX=FFFF, but what happens after that? The source temporary register(which I assume it'll use) should be 0(what remains of the DX temporary shifting value), so after that, 0 will be shifted into AX, thus FFFEh. But it's resulting in FFFFh instead? Does the temporary get reloaded with DX after 16 shifts? Thus shifting left AX::DXcopy::DXcopy2?
Reply 10 of 15, by ripsaw8080
Rank DOSBox Author
DOSBox Author
An issue with shifts greater than 16 bits was recently brought up for Fast Tracker II 2.09 using GUS in DOSBox. According to the Bochs source code, the behavior of SHRD/SHLD changed starting with Pentium Pro, and Bochs now uses the changed behavior. In DOSBox you get the Pentium and earlier behavior with normal or dynrec cores, but the (supposed) PPro and later behavior with the dynx86 core because the instruction executes on the host CPU.
For reference, the attached patch changes the normal core in DOSBox SVN to use the later behavior, which amounts to a different choice of operand.
    DSH_w.diff
    832 Bytes
    14 downloads
Reply 11 of 15, by superfury
So, if I understand it correctly, shifting more than 16 bits on a 386/486 will shift in 0-bits, not the second operand again? So essentially shifting dest::src::0?
Won't that cause compatibility issues on newer processors?
Reply 12 of 15, by BloodyCactus
peterferrie wrote:
It's likely a typo. The result should indeed be AX=0xFFFFE. i.e. shifting in zeroes.
Well, its NOT a typo. its real hardware thanks (k6-2+)
ax=0,bx=0xffff, shld ax,bx,0x11 -> ax=0xffff, bx=0xffff
ax=0,bx=0xAAAA, shld ax,bx,0x11 -> ax=0x5555, bx=0xAAAA
ax=0,bx=1, shld ax,bx,0x11 -> ax=2, bx=1
Reply 13 of 15, by superfury
BloodyCactus wrote:
Well, its NOT a typo. its real hardware thanks (k6-2+) […]
So what happens in that first case on a 80386? If the bx temporary is reloaded after 16 shifts(shifting non-zeroes in), wouldn't that be an 'undocumented' incompatibility with the Pentium(or 80486/80386) right there in the instruction behaviour?
Also, you're saying k6-2+, so are you talking about even more modern processors? I'm trying to figure out it's behaviour on a 80386 (and 80486SX), not a modern CPU(which I don't emulate).
Reply 14 of 15, by BloodyCactus
OK, I'll let you dig out a 386 or 486 (which you know, maybe you should have on hand the hardware your trying to emulate so you can you know.. test it?). I have no interest in breaking out my 486-dx/100 to test for you.
dosbox (built from source about a week ago) with 386 cpu + normal core gives same behaviour. 386 + simple gives me same behavour. penium_slow + dynamic on my i7-4970k also gives me same behaviour as my k6-2+.. sooo dont when ripsaw8080 changed dosbox behaviour but mine does not follow those rules he stated. (I'm on linux, which maybe has some bearing on dynarec core?)
Reply 15 of 15, by ripsaw8080
Rank DOSBox Author
DOSBox Author
DOSBox has not been changed because the Pentium-and-earlier behavior is desired. I only show the changes in the diff for reference of what would be changed to use the PPro-and-later behavior.
In DOSBox you will only get the later behavior with the 32-bit dynamic core (meaning dynx86, and NOT dynrec) because the instruction executes on the host CPU.
