First post, by superfury
I'm currently using some simple, partly precalculated memory access checking on each memory access border(one for the base operand address, one for the highest address(if word or dword)). According to profiling, the basic descriptor check (verifylimit) takes the most time to process(of the CPU emulation).
https://bitbucket.org/superfury/unipcemu/src/ … ion.c?at=master
OPTINLINE byte verifyLimit(SEGMENT_DESCRIPTOR *descriptor, uint_64 offset)
//Execute address test?
INLINEREGISTER byte isvalid,topdown;
topdown = descriptor->PRECALCS.topdown; //Are we a top-down segment?
isvalid = (offset<=(uint_64)descriptor->PRECALCS.limit); //Valid address range!
isvalid ^= topdown; //Apply expand-down data segment, if required, which reverses valid!
isvalid &= (((offset>descriptor->PRECALCS.roof) & topdown)^1); //Limit to 16-bit/32-bit address space using topdown descriptors!
isvalid &= 1; //Only 1-bit testing!
return isvalid; //Are we valid?
Anyone knows how to optimize this?
UniPCemu Git repository
