First post, by superfury
Would a linked list (entry ptr, next ptr, prev ptr in 8 records, initialized linearly) provide a speedup compared to an array-sort LRU method of sorting and placing increasing numbers in the entries themselves?
The TLB has 8 sorted entries, with 4 way association(so 8x4 sets to sort, one at a time)?
UniPCemu Git repository
UniPCemu for Android, Windows and PSP on itch.io
Older UniPCemu PC/Android/PSP releases
Reply 1 of 4, by superfury
Just took a look at https://www.quora.com/Why-is-doubly-linked-li … e-GeeksforGeeks .
After understanding the principles of how it works(in a rough sense; it's pretty simple when you think about it), I started coding myself and came up with this(in UniPCemu's paging code algorithm):
https://bitbucket.org/superfury/unipcemu/src/ … ing.c?at=master
The core of the new TLB LRU algorithm is:
typedef struct
uint_32 data; //80386 4-way associative TLB results!
uint_32 TAG; //All TAGs used with the respective TLB!
} TLBEntry;
typedef struct
TLBEntry *entry; //What entry are we?
byte index; //What index is said entry?
void *prev, *next; //Previous and next pointers!
byte allocated; //Are we allocated?
} TLB_ptr;
typedef struct
TLBEntry TLB[4][8]; //All TLB entries to use!
TLB_ptr TLB_listnodes[4][8]; //All nodes for all TLB entries!
TLB_ptr *TLB_freelist_head[4], *TLB_freelist_tail[4]; //Head and tail of the free list!
TLB_ptr *TLB_usedlist_head[4], *TLB_usedlist_tail[4]; //Head and tail of the used list!
} CPU_TLB; //A TLB to use for the CPU!
void PagingTLB_initlists()
byte set; //What set?
byte index; //What index?
TLB_ptr *us; //What is the current entry!
for (set = 0; set < 4; ++set) //process all sets!
//Allocate a list from the available entry space, with all items in ascending order in a linked list and index!
CPU[activeCPU].Paging_TLB.TLB_freelist_head[set] = CPU[activeCPU].Paging_TLB.TLB_freelist_tail[set] = NULL; //Nothing!
CPU[activeCPU].Paging_TLB.TLB_usedlist_head[set] = CPU[activeCPU].Paging_TLB.TLB_usedlist_tail[set] = NULL; //Nothing!
for (index = 7; ((index&0xFF)!=0xFF); --index) //process all indexes!
CPU[activeCPU].Paging_TLB.TLB_listnodes[set][index].entry = &CPU[activeCPU].Paging_TLB.TLB[set][index]; //What entry(constant value)!
CPU[activeCPU].Paging_TLB.TLB_listnodes[set][index].index = index; //What index are we(for lookups)?
CPU[activeCPU].Paging_TLB.TLB_listnodes[set][index].allocated = 0; //We're in the free list!
us = &CPU[activeCPU].Paging_TLB.TLB_listnodes[set][index]; //What entry are we?
us->prev = NULL; //We start out as the head for the added items here, so never anything before us!
us->next = NULL; //We start out as the head, so next is automatically filled!
if (CPU[activeCPU].Paging_TLB.TLB_freelist_head[set]) //Head already set?
CPU[activeCPU].Paging_TLB.TLB_freelist_head[set]->prev = us; //We're the previous for the current head!
us->next = CPU[activeCPU].Paging_TLB.TLB_freelist_head[set]; //Our next is the head!
CPU[activeCPU].Paging_TLB.TLB_freelist_head[set] = us; //We're the new head!
if (CPU[activeCPU].Paging_TLB.TLB_freelist_tail[set] == NULL) //No tail yet?
CPU[activeCPU].Paging_TLB.TLB_freelist_tail[set] = CPU[activeCPU].Paging_TLB.TLB_freelist_head[set]; //Tail=Head when starting out!
//Move a TLB entry index from an old list to a new list!
void Paging_moveListItem(TLB_ptr *listitem, TLB_ptr **newlist_head, TLB_ptr **newlist_tail, TLB_ptr **oldlist_head, TLB_ptr **oldlist_tail)
//First, remove us from the old head list!
if (listitem->prev) //Do we have anything before us?
((TLB_ptr *)listitem->prev)->next = listitem->next; //Remove us from the previous item of the list!
else //We're the head, so remove us from the list!
*oldlist_head = listitem->next; //Remove us from the head of the list and assign the new head!
if (listitem->next) //Did we have a next item?
((TLB_ptr *)listitem->next)->prev = listitem->prev; //Remove us from the next item of the list!
else //We're the tail?
*oldlist_tail = listitem->prev; //Remove us from the tail of the list and assign the new tail!
listitem->next = NULL; //We don't have a next!
listitem->prev = NULL; //We don't have a previous!
/* Now, we're removed from the old list and a newly unmapped item! */
//Now, insert us into the start of the new list!
Show last 92 lines
	if (*newlist_head) //Anything in the new list already?
(*newlist_head)->prev = listitem; //We're at the start of the new list, so point the head to us, us to the head and make us the new head!
listitem->next = *newlist_head; //Our next is the old head!
*newlist_head = listitem; //We're the new head!
else //We're the new list?
*newlist_tail = listitem; //We're the new tail!
TLB_ptr *allocTLB(sbyte set) //Allocate a TLB entry!
TLB_ptr *result;
if (CPU[activeCPU].Paging_TLB.TLB_freelist_head) //Anything available?
result = CPU[activeCPU].Paging_TLB.TLB_freelist_head[set]; //What item are we allocating, take it from the free list!
//Now take the item from the pool and move it to the used list!
CPU[activeCPU].Paging_TLB.TLB_freelist_head[set]->allocated = 1; //We're allocated now!
Paging_moveListItem(CPU[activeCPU].Paging_TLB.TLB_freelist_head[set], //What item to take!
&CPU[activeCPU].Paging_TLB.TLB_usedlist_head[set], //destination head
&CPU[activeCPU].Paging_TLB.TLB_usedlist_tail[set], //destination tail
&CPU[activeCPU].Paging_TLB.TLB_freelist_head[set], //source head
&CPU[activeCPU].Paging_TLB.TLB_freelist_tail[set]); //source tail
return result; //Give the result!
return NULL; //Nothing to allocate!
void freeTLB(sbyte set, byte TLB_index) //Make an entry available again!
TLB_ptr *listitem;
listitem = &CPU[activeCPU].Paging_TLB.TLB_listnodes[set][TLB_index]; //Our entry!
if (listitem->allocated) //Are we allocated at all?
listitem->allocated = 0; //Mark us as freed!
Paging_moveListItem(listitem, //What item to take!
&CPU[activeCPU].Paging_TLB.TLB_freelist_head[set], //destination head
&CPU[activeCPU].Paging_TLB.TLB_freelist_tail[set], //destination tail
&CPU[activeCPU].Paging_TLB.TLB_usedlist_head[set], //source head
&CPU[activeCPU].Paging_TLB.TLB_usedlist_tail[set]); //source tail
void Paging_setNewestTLB(sbyte set, byte TLB_index) //Tick an TLB entry for making it the most recently used!
TLB_ptr *listitem;
&CPU[activeCPU].Paging_TLB.TLB_usedlist_tail[set]); //Move us to the start of the TLB used list to mark us as the most recently accessed!
else //We're not allocated, but marked as newest? Allocate us!
listitem->allocated = 1; //We're allocated now!
byte Paging_oldestTLB(sbyte set) //Find a TLB to be used/overwritten!
TLB_ptr *entry;
if (CPU[activeCPU].Paging_TLB.TLB_freelist_head[set]) //Anything not allocated yet?
if (entry = allocTLB(set)) //Allocated from the free list?
return entry->index; //Give the index of the resulting entry that's been allocated!
else //Allocate from the tail(LRU), since everything is allocated!
if (CPU[activeCPU].Paging_TLB.TLB_usedlist_tail[set]) //Gotten a tail? We're used, so take the LRU!
entry = CPU[activeCPU].Paging_TLB.TLB_usedlist_tail[set]; //What entry to take: the LRU!
Paging_setNewestTLB(set, entry->index); //This is the newest TLB now!
return entry->index; //What index is the LRU!
return 7;
Then the write/read/init TLB functions use it like this(barely adjusted):
void Paging_writeTLB(sbyte TLB_set, uint_32 logicaladdress, byte W, byte U, byte D, uint_32 result)
byte effectiveentry;
uint_32 TAG,TAGMASKED;
if (TLB_set < 0) TLB_set = Paging_TLBSet(logicaladdress); //Auto set?
TAG = Paging_generateTAG(logicaladdress, W, U, D); //Generate a TAG!
byte entry;
TAGMASKED = (TAG&0xFFFFF001); //Masked tag for fast lookup! Match P/U/W/address only! Thus dirty updates the existing entry, while other bit changing create a new entry!
effectiveentry = 0;
entry = 8; //Init for entry search not found!
do
if (CPU[activeCPU].Paging_TLB.TLB_listnodes[TLB_set][effectiveentry].allocated) //Allocated entry?
if ((CPU[activeCPU].Paging_TLB.TLB[TLB_set][effectiveentry].TAG & 0xFFFFF001) == TAGMASKED) //Match for our own entry?
entry = effectiveentry; //Reuse our own entry!
break; //Stop searching: reuse the effective entry!
} while (++effectiveentry < 8); //Check all entries!
if (entry == 8) //Not found? Take the LRU!
entry = Paging_oldestTLB(TLB_set); //Get the oldest/unused TLB!
else //We're the newest TLB now!
Paging_setNewestTLB(TLB_set, entry); //We're the newest TLB now!
CPU[activeCPU].Paging_TLB.TLB[TLB_set][entry].data = result; //The result for the lookup!
CPU[activeCPU].Paging_TLB.TLB[TLB_set][entry].TAG = TAG; //The TAG to find it by!
//RWDirtyMask: mask for ignoring set bits in the tag, use them otherwise!
byte Paging_readTLB(sbyte TLB_set, uint_32 logicaladdress, byte W, byte U, byte D, uint_32 WDMask, uint_32 *result, byte updateAges)
INLINEREGISTER uint_32 TAG, TAGMask;
INLINEREGISTER byte entry = 0;
INLINEREGISTER TLBEntry *curentry;
TAG = Paging_generateTAG(logicaladdress,W,U,D); //Generate a TAG!
TAGMask = ~WDMask; //Store for fast usage to mask the tag bits unused off!
if (likely(WDMask)) //Used?
TAG &= TAGMask; //Ignoring these bits, so mask them off when comparing!
curentry = &CPU[activeCPU].Paging_TLB.TLB[TLB_set][0]; //What TLB entry to apply?
do //Check all entries!
if (likely(((curentry->TAG&TAGMask)==TAG) && (CPU[activeCPU].Paging_TLB.TLB_listnodes[TLB_set][entry].allocated))) //Found?
*result = curentry->data; //Give the stored data!
Paging_setNewestTLB(TLB_set, entry); //Set us as the newest TLB!
return 1; //Found!
++curentry; //Next entry!
} while (likely(++entry<8));
return 0; //Not found!
Show last 22 lines
void Paging_Invalidate(uint_32 logicaladdress) //Invalidate a single address!
INLINEREGISTER byte TLB_set;
INLINEREGISTER byte entry;
for (TLB_set = 0; TLB_set < 4; ++TLB_set) //Process all possible sets!
for (entry = 0; entry < 8; ++entry) //Check all entries!
if (Paging_matchTLBaddress(logicaladdress, CPU[activeCPU].Paging_TLB.TLB[TLB_set][entry].TAG)) //Matched?
CPU[activeCPU].Paging_TLB.TLB[TLB_set][entry].TAG = 0; //Clear the entry to unused!
freeTLB(TLB_set, entry); //Free this entry from the TLB!
void Paging_clearTLB()
memset(&CPU[activeCPU].Paging_TLB,0,sizeof(CPU[activeCPU].Paging_TLB)); //Reset fully and clear the TLB!
PagingTLB_initlists(); //Initialize the TLB lists to become empty!
I still see Windows NT booting like always, so it can't be that wrong? What are your opinions?
Reply 2 of 4, by superfury
Hmmmm.... Interesting.... When running Simcity 2000 with paging deliberately enabled(with "set dos4gvm=maxmem#4096 virtualsize#32768 swapname#d:\swapfile.swp"), I see it crashing in protected mode over and over again on a FFFFh opcode? Interesting, since it runs fine in normal mode(without paging afaik).
Reply 3 of 4, by superfury
Now trying to run Prime95 under MS-DOS to check for bugs. So far up to DMA controllers pass(Cache memory hangs it seems).
Reply 4 of 4, by superfury
Managed to optimize it a bit by inlining the code and ignoring moving entries from the head to the head of the same queue(so in effect nothing happens, just wasted instructions).
TLB entry allocation/free/LRU/MRU handling:
OPTINLINE void PagingTLB_initlists()
//Allocate a list-to-entry-mapping from the available entry space, with all items in ascending order in a linked list and index!
for (index = 0; (index<8); ++index) //process all indexes!
OPTINLINE void PagingTLB_clearlists()
if (likely(CPU[activeCPU].Paging_TLB.TLB_freelist_head[set])) //Head already set?
if (unlikely(CPU[activeCPU].Paging_TLB.TLB_freelist_tail[set] == NULL)) //No tail yet?
OPTINLINE void Paging_moveListItem(TLB_ptr *listitem, TLB_ptr **newlist_head, TLB_ptr **newlist_tail, TLB_ptr **oldlist_head, TLB_ptr **oldlist_tail)
if (likely(*newlist_head == listitem)) return; //Don't do anything when it's already at the correct spot!
Show last 107 lines
OPTINLINE TLB_ptr *allocTLB(sbyte set) //Allocate a TLB entry!
TLB_ptr *result;
OPTINLINE void freeTLB(sbyte set, byte TLB_index) //Make an entry available again!
TLB_ptr *listitem;
OPTINLINE void Paging_setNewestTLB(sbyte set, byte TLB_index) //Tick an TLB entry for making it the most recently used!
TLB_ptr *listitem;
OPTINLINE byte Paging_oldestTLB(sbyte set) //Find a TLB to be used/overwritten!
TLB_ptr *entry;
return 7; //Safety: return the final entry! Shouldn't happen under normal circumstances.
TLB reads/writes/initialization/clearing:
byte entry;
effectiveentry = 0;
do
return 1; //Found!
Show last 29 lines
if (Paging_matchTLBaddress(logicaladdress, CPU[activeCPU].Paging_TLB.TLB[TLB_set][entry].TAG) && (CPU[activeCPU].Paging_TLB.TLB_listnodes[TLB_set][entry].allocated)) //Matched?
PagingTLB_clearlists(); //Initialize the TLB lists to become empty!
void Paging_initTLB()
Paging_clearTLB(); //Clear the TLB! This also calls clearlists, initializing the linked lists!
