Effect of CS,DS,ES,FS,GS DPL in descriptor cache?
Emulation of old PCs, PC hardware, or PC peripherals.
Postby superfury » 2019-3-10 @ 16:24
According to http://www.rcollins.org/Productivity/De ... Cache.html ,
the CS.DPL==SS.DPL(in reality only SS.DPL afaik?) determines the CPL.
But what effect does DS.DPL, ES.DPL, FS.DPL and GS.DPL have on executing code? Afaik they don't have any effect on segment loads(only SS.DPL, which is CPL and the descriptor load's RPL(only in protected mode(without V86 mode!) afaik?), nor on memory accesses? Why does it document them being required to be 3?
superfury
Re: Effect of CS,DS,ES,FS,GS DPL in descriptor cache?
Postby superfury » 2019-3-10 @ 16:50
Hmmmm... http://www.rcollins.org/articles/loadal ... html#Fig2b
Intel recommends some guidelines for proper execution following LOADALL. The stack segment should be a read/write data segment; the code segment can be execute on1y (access=95h), read/execute (access=9bh), or read/write/execute (access=93h). Proper protected mode operation also requires that the DPL of CS and DPL of SS be equal. These attributes determine the CPL of the processor. Also, the DPL fields of ES and DS should be equal to 3 to prevent RETF or IRET instructions from zeroing these registers.
So the DPL of 3 doesn't affect real-mode code running, but only protected-mode code executing IRET/RETF's security checks(caused by returning to a lower privilege level), as is documented to be the case with said instructions returning in protected mode(EFLAGS.V86 cleared, CR0.PE set)?
superfury
Postby crazyc » 2019-3-10 @ 22:01
superfury wrote:So the DPL of 3 doesn't affect real-mode code running, but only protected-mode code executing IRET/RETF's security checks(caused by returning to a lower privilege level), as is documented to be the case with said instructions returning in protected mode(EFLAGS.V86 cleared, CR0.PE set)?
Right, data segment DPL doesn't matter except when they are loaded or a far return.
DPL of CS might not equal CPL if the code segment is conforming which is why SS DPL determines CPL. RPL of CS is then set to CPL to make sure privilege is correct if a far return is executed back to the conforming segment.
crazyc
Postby superfury » 2019-3-10 @ 23:28
Thinking about it, how does INVLPG work? UniPCemu currently takes the ModR/M segment:offset it refers to(e.g. DS:[EAX] will use linear address DS.base+EAX) and flush any entries that match said address(E.g. when DS points to address 100 and EAX=2000, it flushes the entry/entries for linear address 2100).
Is that correct behaviour? Or is it supposed to read the data pointed to the ModR/M(an absolute pointer in memory) and flush that address from the TLB?
superfury
Return to PC Emulation
Who is online
Users browsing this forum: No registered users and 2 guests
