First post, by es20490446e
es20490446e
Offline
- Newbie
exeCute allows opening exe files as if they were native Linux applications, silently selecting the right emulator and configuration for each case.
Basically it’s s switch. If the file is 16-bit it runs it as a DOS executable, otherwise as a Windows application. So you don’t have to worry what kind of exe it is, it will just open.
https://aur.archlinux.org/packages/execute-git
https://gitlab.com/es20490446e/exeCute
