No sound in Dungeon Keeper on DOS emulation
Emulation of old PCs, PC hardware, or PC peripherals.
Postby jspyder » 2019-5-11 @ 05:59
I'm using VirtualBox running DOS 6.22 and have been trying to get a *working* configuration for Dungeon Keeper. Everything so far works fine, except for the sound - I can run the SetSound utility and it will recognize the sound card as a SoundBlaster 16, but after getting into the game and playing for less than about 15 seconds, the sound cuts out.
I suspect it's a matter of putting the correct Set Blaster configuration in the autoexec.bat, but I'm a rank novice at doing such things - can anyone help me?
jspyder
Re: No sound in Dungeon Keeper on DOS emulation
Postby mr_bigmouth_502 » 2019-5-12 @ 01:17
Try it in DosBox. Virtualbox isn't really suited for gaming.
My NEW(ish) desktop:
User avatar
mr_bigmouth_502
Postby jspyder » 2019-5-12 @ 04:54
Correct me if I'm wrong (I've used DOSBox before), but I'd still need to have the configuration entered in the autoexec.bat, wouldn't I?
jspyder
Postby galland101 » 2019-5-25 @ 23:53
jspyder wrote:Correct me if I'm wrong (I've used DOSBox before), but I'd still need to have the configuration entered in the autoexec.bat, wouldn't I?
DOSBox's sound settings would have to be configured in the dosbox.conf file. You need to define the type of sound card and resources (Address, IRQ, DMA, etc.). You then have to configure Dungeon Keeper through its sound setup program to point to those resources.
User avatar
galland101
Postby mcj » 2019-5-31 @ 16:21
jspyder wrote:I'm using VirtualBox running DOS 6.22
Therein lies the problem. When installing operating systems on VirtualBox, DOS itself does not come with SoundBlaster drivers included (unlike DOSBox).
In your Virtual Machine settings, if SoundBlaster 16 emulation is selected, you will have to install the appropriate SB16 drivers that accompany your 'emulated' sound card.
This way, the correct arguments are set during boot in your AUTOEXEC.BAT and IRQ, DMA, and other settings can be detected properly by games and software.
#win31 forever!
User avatar
mcj
Return to PC Emulation
Who is online
Users browsing this forum: No registered users and 2 guests
