First post, by superfury
I know that the setup of the drivers for MS-DOS and Windows 3.x installs those two drivers. But, seeing as MS-DOS software tends to access the Sound Blaster hardware directly, what's the purpose of those? What are they used for(in what case are thet actually used)?
CTSOUND is the CTSOUND Physical -Level driver
CTMMSYS is the CTMMSYS Integration driver
UniPCemu Git repository
UniPCemu for Android, Windows and PSP on itch.io
Older UniPCemu PC/Android/PSP releases
